Adhesive to secure tap rose head in place
Home › Forums › General Questions › Adhesive to secure tap rose head in place
  • #25923
    JimmieS
      @jimmies
      #348828
      JimmieS
        @jimmies
        The plastic 'rose head' disc on our kitchen mixer tap has come off. Any one suggest a suitable glue to reattach it?
        Jim
        #348839
        Jeff Dayman
          @jeffdayman43397
          Materials to be glued?
          Photos of each part?
          Can likely help but need more info.
          #348840
          John Rudd
            @johnrudd16576
            Superglue/epoxy/contact adhesive/pva/spit….cheeky
            #348875
            Brian Sweeting 2
              @briansweeting2
              Thought they were normally screwed on, check inside the spout.
              #348991
              JimmieS
                @jimmies
                The tap spout end consists of the plastic rose with a smaller diameter flexible tube which is a posh fit into the rear of the rose.img_1425.jpg
                #349969
                Jeff Dayman
                  @jeffdayman43397
                  Where's it broken? Can't see a break. Can we see the broken pieces apart (or the other part to be glued)?
                  Not enough info so far to be able to offer any suggestions. Don't know what you mean by a posh fit, and only guessing what you mean by a "rose", that is, maybe it's the bigger diameter end of the part with multiple passages as shown in your photo.
                  Maybe your terminology is 100% clear locally where you live, but it isn't clear to me. I've been designing valves and plumbing components at different times for several different fluid handling firms in North America for many years, so I can probably help, but need clear info to do so.
                  Edited By Jeff Dayman on 12/04/2018 16:08:05
                  #349986
                    They are usually a push fit, but sometimes screw in. I have seen push in ones pop out before.
                    Do you know the manufacturer?
                    P.S. the part is a 'tap aerator'
                    http://www.tapsandsinksonline.co.uk/?s=aerator&post_type=product
                    Edited By Neil Wyatt on 12/04/2018 18:36:48
