A red face and a bottlejack
Home › Forums › General Questions › A red face and a bottlejack
  • #478453
    Andrew Tinsley
      @andrewtinsley63637
      Like many here, I have been having a mega tidy up during lockdown. I found a 4 ton Lake and Elliott bottle jack, last seen some 35 years ago!
      I cleaned it up and freed the stuck threaded top section. I checked the oil level (it had been leaking as it was on its side). Topped up with hydraulic fluid and gave it a pump or three. It eventually got to full height and then the awful truth dawned. How do you let it down? I must have known once!
      There was no sign of a release valve and the only visible features were the oil filling point and the device to put the pumping handle into (this just drives a horizontal shaft to pump up the jack). Now there is a spring loaded lifting device on this, which needs to be lifted to get the handle out. But this is ALL it does. There is also a floppy lifting handle, but this doesn't do anything else. It is a very heavy brute and the handle is needed.
      So, I have an erect jack (no comments please) and no apparent way of collapsing the ram. I have a very red face indeed but I am confessing my sins in the hope that someone can tell me how to retract the ram.
      Andrew.
      #27431
      Andrew Tinsley
        @andrewtinsley63637
        #478455
        Adrian R2
          @adrianr2
          Try pushing the handle all the way down and holding it there, I've got a couple that work like this. It may be reluctant to compress if not under load so you might have to apply some force to the top as well.
          #478456
          David Jupp
            @davidjupp51506
            Not sure if it was the same make – one I used years ago was released by pulling the handle back slightly from the slot in the 'rocker' – this allowed the handle to be depressed further than when pumping, allowing the oil to 'return to tank'.
            It needed a significant push down on the ram if not actually carrying a load, the weight of the ram alone wasn't enough to force the fluid back round the circuit.
            #478458
            Anonymous
              Put it aside for another 35 years.
              #478462
              Andrew Tinsley
                @andrewtinsley63637
                Thanks gentlemen,
                That rings a bell, however in my enthusiasm to pump the jack up, I have pumped the ram to the top and cannot get the pump handle to go down. I am sure that if I leave it long enough, then slight leakage will allow me to get the ram down a touch to enable me to "bottom" the pump handle.
                I did notice that there seemed to be two positions for the pump handle at maximum height. I just thought that this was due to a 35 year lack of use. Maybe the two positions at the top are the equivalent of your two positions at the bottom, I will check, as I can lift the handle.
                Before anyone cautions me not to use the jack, it would not be put to use without a strip down and seal replacement,
                Thanks all.
                Andrew.
                Edited By Andrew Tinsley on 08/06/2020 15:20:09
                #478468
                Andrew Tinsley
                  @andrewtinsley63637
                  Hello again,
                  Just got the jack down by forcing the handle to its lowest point, so you were right on the money Adrian! Thanks, my face is no longer red!
                  Now wait a minute Andrew. I shall not be putting it away for another 35 years, UNTIL it has been overhauled and fettled.
                  Come to think, I won't be around in 35 years (my friends are dropping dead like flies now). It will be the executors of my estate that will dig it out again!
                  Andrew.
                  #478485
                  Brian Wood
                    @brianwood45127
                    It probably doesn't need stripping at all, but if you do so take care that spring loaded balls do not leap out of sight, You may also need some odd sizes of O rings before you rebuild it. Just undoing the big nut at the bottom of the ram cylinder will be be a challenge. I seem to remember the bottom plate allows a way in too.
                    I would leave it alone and tolerate the cost of topping it up
                    Best of luck Brian
                    #478495
                    larry phelan 1
                      @larryphelan1
                      Amen to that ! Let sleeping dogs lie !
                      #478501
                      Andrew Tinsley
                        @andrewtinsley63637
                        You could both be right. It was only leaking from the filler because it was on its side. Maybe clean it off and give it a coat of paint. The executors won't know!
                        Andrew.
                        #478505
                        Brian Sweeting 2
                          @briansweeting2
                          Maybe write some instructions down and put in a plastic bag, then tape it to the jack.
                          #478509
                          AdrianR
                            @adrianr18614
                            Put a clause in your will, they don't get a penny unless they can raise and lower the jack
                            #478511
                              Posted by Andrew Tinsley on 08/06/2020 15:19:06:
                              Not a bad idea to assume all hydraulic jacks have untrustworthy seals. Jolly useful devices but I'd never go underneath one without putting a stand in first. Screw jacks are dodgy too – I've had one roll over whilst changing a wheel when one side of it's base sank into the road – apparently tarmac isn't rock solid.
                              Dave Halford
                                @davehalford22513
                                Posted by SillyOldDuffer on 08/06/2020 18:12:27:
                                That one is even funnier if it's a hot day and a new motorcycle left on the side stand, goes down like a falling tree – strangely except when it's yours.
                                To be serious, scissor jacks were worse for that
                                #478547
                                Howard Lewis
                                  @howardlewis46836
                                  If it is any consolation, I have painted myself into that corner, with hydraulic jacks, many times!
                                  But been able to summon enough brute force to force the handle down to release the pressure.
                                  #478561
                                  old mart
                                    @oldmart
                                    When you mentioned hydraulic fluid, my immediate thoughts were " I hope it was not DOT4". wink 2
                                    #478564
                                    Nicholas Farr
                                      @nicholasfarr14254
                                      Hi, you should never put any part of your body under anything supported by a jack of any type, whether it's brand new or years old. I have a 300mm approx' square and about 30mm thick, very tough piece of plastic in my car, that I use to stand my jack on whenever I have to jack it up and if I'm just changing the wheel, I put the one I take off, under the sill until I've fitted the other one on, then if for some reason the jack gives way, the car won't fall down very far.
                                      Regards Nick.
                                      #478636
                                      Perko7
                                        @perko7
                                        My dad always told me that when jacking up a car to change the wheel, always put the spare wheel under the side sill of the car while jacking up so that, if the jack slips while the crook wheel is off, the car won't hit the deck. Still using a bottle jack of indeterminate age (certainly over 80 years old) which has never failed but you can't be too careful.
                                        #478647
                                        Andrew Tinsley
                                          @andrewtinsley63637
                                          Hi Old Mart,
                                          I always use pukka hydraulic fluid for jacks. I was given a lifetimes supply of brake fluid it is a pity I can't use it in jacks.
                                          Andrew,
