A little ‘Toy’ History
Home › Forums › The Tea Room › A little ‘Toy’ History
  • #646237
    IanT
      @iant
      I was interested to see John Arrowsmith's article about Gauge '2' but I don't think his description of Gauge '2' originally being 64mm gauge or a scale ratio of 1:22.5 is correct.
      The 'gauges' introduced by Marklin in 1891 were Gauge I (48mm), Gauge II (54mm) and Gauge III (75mm). It should be noted however that these measurements were made from the centre of each rail (and not the inside rail edges). If we assume a common rail width of 3mm, then (by todays standards) we would call them 45mm, 51mm and 72mm respectively. So Markilin Gauge 'II' was 51mm which converts almost exactly to 2" (2.008" ). Nor was the scale 1:22.5 – it was 1:28.25 (as a comparison, Gauge '3' is correctly scaled at 1:22.6  – with LGB 'G' being 1:22.5 (Metre-gauge on 45mm track)
      Please also note that Marklin Gauge 'III' is not the same as the (UK) Gauge '3'
      I think the confusion with respect to Gauge '2' being 64mm probably arises from the fact that the German IG Spur II group use 64mm track for it's standard gauge stock (and 45mm (Spur IIm) & 32mm (Spur IIe) track for it's narrow gauge stock – all scaled at 1:22.5) See IG Spur II for further detail…
      The early days of "Toy" railways was very confusing in terms of the gauge 'standards' , with many vendors using either different names for the same gauge or different gauges with the same name. There is a brief history of this confusion on the G3S website. See A Little Toy History
      However, In the UK the five standard model gauges were recommended by a subcommittee of the Society of Model Engineers on 1st February 1899 and (of course) these gauges were stated in Imperial measure. Now you can convert these gauges into metric (as is now common in G1 and the smaller scales) but they were originally all defined in Inches. So G3 is not 64mm, it's 2.5" or if you must use millimetres then 63.5mm – not because the 0.5mm is crucial but because it confuses two different based standards – Metric & Imperial.
      Anyway, not to detract from an interesting article – just to trying to correct a small detail before it becomes part of the accepted 'lore'.
      IanT
      Edited By IanT on 23/05/2023 00:22:44
      #37226
      IanT
        @iant
        Confusion about early model railway scale and gauges…
        #646243
          Posted by IanT on 23/05/2023 00:21:41:
          Not my area of interest, Ian … but I greatly admire your attention to that important historical detail.
          Weary
            @weary
            And surely needs drawing to the attention of Model Engineer Magazine's editor so that a clarifying addendum to the original article can be printed?
            Phil
            Edited By Weary on 23/05/2023 07:20:26
            #646263
            David Viewing 1
              @davidviewing1
              Thanks to Ian T for that illuminating clarification on the origin of Gauge 2.
              As Ian states, the SME defined the Gauge as 2" in 1899, for which Henry Greenly is given credit.
              The UK model railway industry stuck fairly well to this definition although it is sometimes referred to as "50.8 mm"!
              Greenly was clear on the issue of scale as 7/16" / ft or 1:27.43 (rounded to 2 DP). However manufacturers were rather less scale concious in Edwardian times than today, and many of Bassett Lowke's 'Scale Models' were foreshortened. Even some Model Engineer Exhibition award winning rolling stock was built using oversize (Presumably G3) components!
              However, Gauge 2 models produced before WW1 by James Carson and C. Butcher stand out as being built to true scale. This message was clearly being received in Northampton because the last G2 model to appear before 1914, Bing's "Saint George", was built to a reasonable scale standard. This makes for an impressive model and I've had the great pleasure of running one of these, perhaps for the first time in a very long time, in the last couple of weeks.
              #646267
              noel shelley
                @noelshelley55608
                Very interesting ! Thank you. Noel.
                #646272
                IanT
                  @iant
                  Posted by David Viewing 1 on 23/05/2023 09:37:38:
                  Greenly was clear on the issue of scale as 7/16" / ft or 1:27.43 (rounded to 2 DP). ……..
                  Yes David, manufacturers were very 'loose' in terms of "scale" and approximations were used.
                  In the history of Gauge '3' – early 2.5" gauge stock was built to 1/2" scale (with 3.5" gauge being 3/4" and 5" being 1" "scale). This persisted until sometime between the great wars, when the scale in general use for G3 changed to 17/32" . Not everyone followed suite and some very well known 2.5" builders continued with 1/2" scale (CM Keiller for example). Gauge '2' never really went through this evolution as (stated in the article) it fell out of fashion fairly quickly with the larger retailers tending to simplify the choice of gauges offered.
                  With regards "True Scale" that is very simply stated as being the track ratio between prototype & model. In UK 'standard' gauge terms that involves dividing 56.5" (4ft 8.5" ) by the model track gauge in inches. You can then use that scale ratio to come up with the "scale" normally referred to (or to find out how far adrift it is). So G2 (track ratio 1:28.25) is 0.425" (10.8mm) per foot "true scale" (with 7/16" being 0.4375" (11.11mm) per foot). It's interesting to note that G2 at 7/16th was over-scale, whereas G3 at 1/2" was underscale. One of the drivers to moving to 17/32" in G3 was the desire for larger mechanical clearances but this pressure would not have been present in G2.
                  So there we have it. All the larger 'scenic' gauges quickly declined after WW2, with the smaller "Table-Top" model railway scales becoming not only far more affordable but also practical for indoor layouts. In terms of scenic garden railways, 16mm (N/G on 45/32mm track) was the first to 're-emerge' followed by G1 and then (some 20 years later) by G3. We are all constrained of course by the availability of track to run on but also by the availability of new product. It's taken over 30 years to build G3 back to the point where it is no longer just a 'scratch builders' scale with a good range of commercial support. With the advent of laser and 3D print technology some of these barriers are being reduced but I think G2 is unlikely to be anything but a Collectors gauge looking forward – but of course a few dedicated enthusiasts can make a huge difference (as was the case with G3).
                  I wish them every success.
                  IanT
                  Edited By IanT on 23/05/2023 11:23:23
