Philip
I have just completed a ST#1 (see my post of 21 Aug. in the "work in progress" thread) and it turns over with some drag which I put down to the ring friction in the bore, but I wouldn't call it tight. It uses the supplied ST rings and are fitted with an approximate 3-4 thou gap. During initial testing I assembled it without the rings and it that state it just spun over easily and if the flywheel was given a good spin it would coast for 2 or 3 revs. Try assembling yours without the rings and see how it goes, it may be just the ring to bore friction that is causing the tightness. How thick are your rings? The ones from ST in mine are .0955 thick, which are by all accounts considerably thicker than optimal. The wall pressure may be higher than optimal. I found that I could remove the rings without disassembling the whole top end by removing the the top cover, and with the piston at TDC the nut could be undone and the top half of the piston unscrewed. Lowering the crank to BDC then left the rings in the top of the cyl. and could be removed. With the crank back up at TDC the piston could the be re-assembled. I must have done this a half dozen times!
Edited By John Purdy on 12/10/2019 18:40:52
