What are ‘spring’ collets?
Home › Forums › Beginners questions › What are ‘spring’ collets?
  • #425407
    Ian P
      @ianp
      I have always wondered what people were referring to when they mention spring or finger varieties of collets.
      I just Googled 'what are spring collets?' and the first definition from Google itself is this,
      Spring collets are perishable tools for fixing a workpiece at the processing, or fixing cutting tools, and used as some parts of a machine or a conveyance machine. … On the other hand, when we use spring collets, a workpiece is clamped as wrapping in with the number of flexing slot of the collet.
      So now I know!
      Not that I am any wiser
      Ian P
      #9813
      Ian P
        @ianp
        For that matter, what are ‘Finger’ collets
        #425425
          Ian,
          As I understand it; Spring collets are the ones that are:
          • only split from one end
          • usually pulled in by a draw-bar [but other arrangements are available]
          • only handle a specific diameter [or section] of material
          Watchmaker's style … but available in many sizes
          ER collets, by contrast, are 'soggy' because they are split from both ends.
          Edit: Here is some bedtime reading
          http://www.rotagriponline.com/datasheets/5C.pdf
          Edited By Michael Gilligan on 21/08/2019 23:41:49
          #425616
            In case anyone is wondering [which it would appear they are not]: Adjectives such as 'spring' are included for clarification …. because 'collet' also has other meanings [e.g. in armoury, jewellery, and horological work] where it is merely a ring/band/collar, rather than an an adjustable device.
            Ian P
              @ianp
              The Rotagrip document that Michael gave a link to does contain some information about spring collets. I've not quite worked out what differentiates them from outwardly identical but non spring versions of the same collet.
              Nowhere does it mention finger collets though so I'm no wiser on that score.
              Ian P
              #425625
                Posted by Ian P on 23/08/2019 09:42:14:
                The splits in a 'spring collet' divide it into 'fingers'
                Anonymous
                  I would regard 5C collets as spring and finger collets, whereas ER collets are spring collets only. A spring collet relies on the springy properties of the body material unlike collets such as the Burnerd multisize series, which have a series of separate tapered wedges that slide within the body as the collet is closed. Or rubberflex collets which have a series of metal wedges connected by moulded rubber.
                  #425627
                  Ian P
                    @ianp
                    Posted by Michael Gilligan on 23/08/2019 09:47:53:
                    I always regarded the individual sections as 'Tines'.
                    ER collets do not really have Tines though (as the finger is attached at both ends)
                    Ian P
                    #425628
                      Posted by Ian P on 23/08/2019 09:54:06:
                      1. That must be because you're Posh
                      2. Agreed
                      P.S. the 5C 'emergency collets' are not very springy, because they are intended to be further machined to requirement, by the user.
                      Edited By Michael Gilligan on 23/08/2019 10:01:40
                      #425643
                        Posted by Andrew Johnston on 23/08/2019 09:52:28:
                        An interesting distinction, Andrew yes
                        But I am left pondering … Does the 'spring' necessarily have to be integral to the body material ?
                        • Multisize incorporates wire springs
                        • Rubbeflex incorporates rubber springs
                        Not arguing … just wondering
                        Tim Stevens
                          @timstevens64731
                          Might finger collets refer to collets comprising sets of individual (matched) fingers – so that the collet could be used in cases where a more conventional collet would not go over an obstruction? In other words, take an ER collet for example, and grind away the connecting bars between the fingers (having first, I guess, marked each finger in number order?).
                          And in my view, an ER collet is a spring collet, just not a very strong spring.
                          But what do I know?
                          Cheers, Tim
                          #425792
                            Posted by Tim Stevens on 24/08/2019 16:06:32:
                            [ … ] And in my view, an ER collet is a spring collet, just not a very strong spring.
                            Can't disagree, Tim
                            I simply offered an hypothesis, to get others thinking about Ian's question.
                            Perhaps Neil [who wrote the dictionary] will be along to provide a strict definition.
                              For what it's worth: This article includes the term "finger collet" [and some pretty pictures]
                              Tooling & Workholding: Making Out-of-Round Parts Round
