Good inserts For (t6 i think) aluminium
Home Forums Beginners questions Good inserts For (t6 i think) aluminium
  • #9782
    Nathan Turner 1
      @nathanturner1
      #422169
      Nathan Turner 1
        @nathanturner1
        I have a six inch rough Alu disc that i would like to face off and use as backing plate for a gem faceters plate which is quite flat, i'd like a nice finish so any recommendations would be brilliant, thanks in advance
        #422287
        DC31k
          @dc31k
          It would be beneficial to you to tell us what holder you have for the inserts (i.e. the insert shape).
          Assuming you have a rhomboid one, I have had good luck with Korloy CCGT inserts. Available on eBay via China if you do not mind waiting, or Cutwel Tools.
          In general, aluminium inserts will have a 'G' in the code (for ground/polished after sintering) and will be shiny silver in colour and very sharp.
          Be sure not to get ones for aluminum, or you will have to source your material from USA.
          #422293
          Hollowpoint
            @hollowpoint
            I agree with the above. The CCGT tips work a treat. You can get an almost Glass like finish with these if you take a fine finishing cut at high rpm. 👍
            #422622
            Nathan Turner 1
              @nathanturner1
              Brilliant thanks for the recommendations, i'm waiting for the lathe i want to either come into stock or something similar so i'll be ordering some as soon as it arrives.
