Metric threading on Imp Lathe
Home › Forums › Beginners questions › Metric threading on Imp Lathe
  • #9720
    Bevel
      @bevel
      #414344
      Bevel
        @bevel
        Hi All,
        Hope somebody can advise please.
        Currently running a WARCO WM250V imperial lathe but need to cut a 1.5 pitch thread.
        I have the standard supplied gear set ie. 20,30,40,50,55,60,63,70,75 + 80.
        Is there anyway I can cut this thread using these gears?
        Also apart from the gear train can anyone explain what these illustrations on the upper outer casing mean?
        Many thanks gents,
        Nicky
        #414369
          Nicky your image has not come out but I assume you have similar to this though there are a few WM250 variants.
          The top chart is the fine feed chart with cuts along teh lathe shown first followed by finer cuts, below that are the metric pitches and then the imperial ones.
          The group of circles is basically what you would see if you take the end cover off the lathe and look at it from the end. The top left circle is the fixed 40tooth gear on the spindle, then you have two pairs of gears Z1-4 on studs which can slide along the banjo and finaly gear L on the end of the lead screw.
          You can now look down at the table and it shows what gears need to go in the Z1-4 positions as well as L to get the gear you need. AB&C are the position of the front lever eg one gear train will give 3 pitches. H on the chart means a spacer.
          So for 1.5mm itch you need 63T and 80T on tehtop stud with teh 80T nearest the headstock, then 80T and 60T on the next stud with 60T nearest the headstock and finally a spacer and the 50T gear on the lead screw with 50T nearest the headstock and select lever position A. The studs can slide on teh banjo to mesh the gears correctly and the banjo also pivots around the leadscrew to adjust mesh with the fixed 40T spindle gear. You should have two 80T gears.
          You won't get an exact 1.5mm pitch using a 63T in the train but the resulting 1.477mm should do for most things.
          Edited By JasonB on 15/06/2019 13:24:53
          #414387
          Bevel
            @bevel
            Hi Jason,
            Thanks very much for your detailed reply much appreciated.
            Odd the picture didnt show cos it's showing here on my PC but yes its the same as the one you supplied. I did grasp the initial set-up for threading thank you, it was the feed part of the diagram I didnt get to be honest.
            Don't know about yours but my user manual shows different gear train set-ups for threading compared to the outer-cover? The outer-cover references a 39T gear? Upon checking the manual I did notice the twin 80T option but don't think I have 2 of them in my kit.
            I'll have to check, failing that it's cheaper just to buy a split die than a new gear/gears.
            Great to have this resource for queries cos even though I been in trade for last 30years+ I never owned any machinery myself and it's like doing my apprenticeship again lol.
            Best regards,
            Nicky
            #414389
              I actually have a 280 but there are quite a few 250 owners here who will hopefully chip in later.
              The feeds are really nothing more than very fine threads so you set them up in the same way, having said that in the 10 years that I have had my 280 I just use the finest setup and use the lever to get 3 feed rates which seems to work OK for me, you do still get a very fine facing cut with the lever in the "C" position even though it is shown blank
              #414396
              Bevel
                @bevel
                Think I have mine set up on the higher of the 2 shown.
                Just checked only got one 80T gear unfortunately, and only need to cut the one thread presently would you believe it.
                In your experience would you think it worth me starting a thread asking for a spare 80T gear?
                Bet there are loads of spares out there forgotten about in back of Dad's old workshop. Is there a 'Wanted' facillity on the forum Jason?
                TIA
                #414397
                Niels Abildgaard
                  @nielsabildgaard33719
                  Posted by JasonB on 15/06/2019 13:19:02:
                  80 divided by 63 makes 1,26984 that is very close to the magic 127/100.
                  Pitch will be1,4998mm not 1,477 me think
                  Another almost but not cigar combination is 47 divided by 37 that gives 1,2702 or again an error of less than hobby measurable
                  #414403
                  Bevel
                    @bevel
                    Hey Niels,
                    Much respect cos I have no idea to be honest.
                    Don't really understand what all that means I won't lie so please can you tell me in simple terms if I can machine the 1.5 pitch, or therabouts, with a combination of the gears I already have and if so how I arrange them?
                    Most probably knowing my luck I'll have to procure something additional as life never seems that easy to me.
                    Cheers
                    #414405
                    Pete Rimmer
                      @peterimmer30576
                      No you won't but the error is less than the average leadscrew tolerance. Here's a standard metric threading plate from a Colchester with a 6tpi leadscrew. They did metric transposing from the factory without using a 127 tooth gear.
                      #414407
                        Problem is all the old change gears knoocking about are going to be imperial you need a metriv MOD gear. Not too expensive to buy a stock gear from someone like Beltingonline and modify it to fit.
                        Neils you are right it's a lot closer I hit 3.125mm for the leadscrew pitch not 3.175blush should come out at 1.50019
                        Not sure if it will fit on the banjo but you could try 40T spindle driving 80T, 63T driving 40T, 60T driving 50T on leadscrew and put the lever in C. Which basically doubles the drivetrain pitch but by changing the lever you run at half that.
                        #414410
                        Bevel
                          @bevel
                          Jason,
                          is this what your proposing fella?
                          63 80
                          I
                          40 60
                                I
                          H 50
                          Edited By Nicky Ireland on 15/06/2019 19:03:34
                          #414411
                            That's it. just not sure if you will get the smaller gears to mesh without leaving a gap.
                            #414419
                            Bevel
                              @bevel
                              Well I'll give it a bash and let you know how I get on
                              Thanks chaps
                              #414434
                              old mart
                                @oldmart
                                Try out the settings first by just touching your threading tool on a bit of barstock to leave a mark that will enable the pitch to be checked. 1.5mm pitch will be 20 threads per 30mm length.
                                #414436
                                Pete Rimmer
                                  @peterimmer30576
                                  I always make my first threading pass with a black marker. Just hold it against the tool with the tip touching the work. Check the marks with a thread gauge..
                                  #414529
                                  Bevel
                                    @bevel
                                    Guys,
                                    A huge thx to all for all your input, great to have your advice its very much appreciated.
                                    Nicky
                                    #414679
                                    Bevel
                                      @bevel
                                      Hats off to you all, took some faffing and had to make couple of little items but 1.5 pitch achieved with recomendations you all gave.
                                      Huge thanks to everyone who contributed.
                                      Nicky
