Hi everyone apologies for delay but I still have to work to pay for the parts!
Camera bust so had to use my phone I found that although the article says 1/4″ square all round for foundation ring, probably due to me when I assembled the boiler it was more like 3/16 on the sides and 1/4 front and back. I made the side pieces 1/4″ deep by 3/16 hence they look different sizes on the photos of the bottom, so there was minimal gap into which the solder had to run.
I’m a beginner as I believe Chris is – one thing I found when silver soldering this even with a large Sievert burner is that you have to insulate the boiler away from where you’re trying to silver solder or it takes ages to reach working temperature – I used broken firebrick round the barrel and stood the boiler on firebrick and it seemed easier.
There isn’t much to the base – I attach some photos. Though not specifically mentioned I completed as much as I could of the firebox and soldered it up. I found fitting the top stays to the inside of the main boiler tube accurately to be helped by putting in 4 x 1/16″ rivets which helped to keep it all aligned whilst fitting the foundation ring. Also made sure the bottom of the firebox and the outer tube were flat on surface pate when all assembled dry (linisher took out any minor unevenness)
Loads of flux on the parts after pickling in Citric Acid, then soldered it in with the backplate all at next firing. I’m then going to insert and solder the stays and throat tube and bushes at the next session note I’m building the superheated version hence the two larger holes at the throatplate).
Haven’t included a specific photo of the tube but drilled a 1″ hole in a block of hardwood, heated the 1″ tube to anneal (be careful – too much heat and it’ll melt – thanks to GLR for the free replacement) and flanged with a peen hammer.
All in all took a bit of time to get everything lined up but not nearly as bad as I had feared.
NOW THE BAD NEWS UNFORTUNATELY I MOVED TO AN IMAC AFTER SOME YEARS ON LINUX
THIS APPEARS TO BE INCOMPATIBLE WITH THE SOFTWARE BEING USED ON THIS THREAD AS FAR AS IMPORTING IMAGES – IT WONT ACCEPT CUT & PASTE OR DRAG & DROP IMAGES; OS X DOESN’T HAVE an “album” i have tried pasting the url and it just doesn’t show in the post and I tried creating an “album” folder and pointing it to that and it doesn’t do that either!!
anyone who needs to see the pics (Chris??) email me directly on
[email protected] and I’ll forward an email with the pics attached
Donald Campbell
