Octopus Heat Pump
Octopus Heat Pump
Home › Forums › The Tea Room › Octopus Heat Pump
Viewing 25 posts - 1 through 25 (of 119 total)
  • #864259
      I am being encouraged by Octopus Energy, to apply for the £9k grant towards a Heat Pump [replacing my Oil boiler]
      I have a lot of thinking to do, but meanwhile I would welcome any comments about the actual contraption that they are offering:
      https://octopus.energy/heat-pump-explore/
      David Jupp
        @davidjupp51506
        The Octopus unit uses propane as the refrigerant, hence it is capable of generating higher output temperature than many heat pumps.  Use of propane is a relatively recent development.
        #864273
          Thanks for that, David
          peak4
            @peak4
            I can’t comment on what Octopus (my own supplier) are offering, as we’ve currently decided not to go down that route.
            Much of the advantages may be lost on us in a large house with 30 year old insulation standards.
            We currently use a mains gas boiler system, with one additional gas fire, so may well have come to a different conclusion if we were on propane or oil.
            This article by Dale Vince’s group may give further food for thought; he’s not against heat pumps themselves by the way.
            https://dalevince.com/reports/the-cold-hard-facts-about-heat-pumps
            Bill
            #864275
            Martin Connelly
              @martinconnelly55370
              If you have solar panels then you can think of a hot water system as being like an energy storage system for the solar energy. So if you are getting low cost mains electricity at night and solar electricity during the day there may be a good saving to make if oil prices are rising fast.
              Martin C
              #864276
                Do keep us informed if you go ahead. I see endless ‘offers’ of £7k grants so maybe they are upping the ante – or pretending to.
                <interrupt> at this point while writing my reply I got a rare landline call which was a recorded message claiming to be from some power distribution company. Coincidence? Excuse me while I scan the house for hidden cameras.
                I suspect the grant is dependant on you spending £30k on upgraded radiators, windows, insulation and a far bigger heat pump than necessary to mimic the output power of an overspec’ed gas boiler. All sourced from the contractors giving the biggest kickback to the heating consultant. (that job creation scheme Boris introduced after lockdown.)
                We really all need to cut back to only heating one room to 68F max like we grew up with.
                #864281
                  The recent posts are all welcomed, but largely irrelevant to my case
                  I shall be asking Octopus some questions
                  Please keep the comments coming
                  JA
                    @ja
                    Bill
                    Like most, Dale Vince (of Forest Green Rovers and a green electric company) has his agenda. However it does seem to be a well balanced and interesting article.
                    I doubt if I could get any grant for a heat pump or improving the insulation of my house. If I could get a grant to insulate the workshop …..
                    I have not seen advertised a dual air conditioning and heating heat pump yet. I am sure they have arrived or will come soon.
                    JA
                    #864283
                      Special thanks to Bill for the link, from which I quote:
                      Heat pumps work best in homes that are:
                      Well insulated
                      Low heat-loss
                      Able to run low-temperature heating systems
                      Significantly … My little house currently fails every one of those criteria !
                      The project to upgrade it has only recently commenced
                      Graham Meek
                        @grahammeek88282
                        Well insulated
                        Low heat-loss
                        Hi Michael,
                        Our house is a 74 years old Semi. We have insulation in the cavity, double glazed doors and windows, plus double the normal loft insulation. Our current gas boiler is doing fine.
                        The problem I have with the Heat Pump, although I am not dead against them. Is the amount of space required to house the ancillary equipment. Some of the installations I have seen on TV take up the size of our small bedroom or half the size of the Garage when it is close to the home. Mine is 30 metres away, and is the workshop, so currently hallowed ground.
                        While there is room in the attic some serious restructuring of the ceilings would be required. Being the same age as the house do I really want all the hassle, and invest money in something for someone else to benefit from?
                        Good luck with the choice,
                        Gray,
                        #864290
                          Pete Rimmer
                            @peterimmer30576
                            Just to note that the government 0% vat on heat pump installations expires March 31st next year. After that you pay 5% vat on them, so getting in before then will save you 5%.
                            To qualify you have to have the equipment both supplied and installed by the same person/company.
                            This also applies to permanent install air-con systems BTW.
                            #864303
                            David Jupp
                              @davidjupp51506
                              Be aware that to get the grant, you will need a report showing that your building doesn’t need any work to meet the insulation etc. requirements of the scheme.
                              I had to get some additional loft insulation (at my expense) to bring it up to current standards, before qualifying for the grant for my heat pump.  The cost of the survey may be ‘free’ (but rolled into final cost, by the heat pump provider).
                              That extra insulation led to issues with condensation in the loft – fairly easy to resolve, but the insulation contractor wasn’t interested!
                              Some companies are only interested in the grants, and are not good technically.   I had more than one company tell me my house was not suitable, due to microbore piping.  House  heating and hot water now provided by heat pump, heating still by microbore – one radiator upgraded.
                              #864305
                              Robert Atkinson 2
                                @robertatkinson2
                                I assume this is an air-water heat pump. The prime question is how hot the water is. Some systems require larger radiators and plumbing. If you have microbore pipework it may have to be replaced. The next question is how much will you have to pay on top of the grant?
                                Personally I went for air-air heat pumps in both my previous flat and current home. No grants but has the huge advantage of providing cooling as well as heating. That has been great over the last couple of months. Went for a multi-split system so only two outdoor units for 5 rooms. For some reason the installers were pushing for a 1:1 setup which is daft. We have a mix of gas and electric for water heating. Both on-demand so no stored hot water loosing energy and warming up the house in warm weather.
                                Robert.
                                #864331
                                  If that’s true, David [and I can see no reason to doubt your word], the project is already dead.
                                  I have written to the Octopus, seeking some clarification.
                                  John Haine
                                    @johnhaine32865
                                    Michael, I sent you a PM.
                                    #864367
                                    Adrian R2
                                      @adrianr2
                                      My thoughts:
                                      The actual contraption from Octopus looks like a council bin and I wouldn’t want one on my property.
                                      I wouldn’t do anything just because it came with a government grant attached, it has to make sense on its own merits.
                                      A2A with both heat and cool modes as per Robert’s post make a lot of sense with hotter summers, these were initially excluded from incentive schemes but are now I think also in scope so you might want to get a quote for that as well and compare.
                                      All in one units (e.g. Panasonic RAC solo) are also available if you don’t want or can’t have stuff outside.
                                      #864368
                                        Thanks, Adrian
                                        You’re spot-on with the visuals !
                                        and I agree that Air-to-Air makes a lot of sense, conceptually …
                                          For info.
                                          I wrote to Octopus yesterday, and am awaiting their reply
                                          Subject: Heat Pump to replace Oil Boiler
                                          I have just submitted my house name for an instant estimate
                                          **** ***   CH8 ***
                                          This looks attractive, but I have some special circumstances which I need to discuss
                                          Basically, the house is in need of extensive thermal upgrading … a ‘rolling’ project which I have just commenced. … But of course I am keen to get the £9k whilst it is available.
                                          Could you please therefore advise me : What is the minimum installationwhich would qualify for the grant ?
                                          In the short-term, I would be happy to have a heat pump providing hot water and driving a couple of radiators [all on the ground floor] and would use electric heating elsewhere.
                                          I can then extend the system as-and-when appropriate insulation has been installed.
                                          The property is a very small Dormer-Bungalow, which presents some “interesting” challenges …but I have engaged an excellent contractor to work with me.
                                          I look forward to hearing from you.
                                          #864385
                                          Macolm
                                            @macolm
                                            Robert, I presume a substantial advantage of the air-air implementation is a lower delivery temperature of the air rather than the higher temperature needed for water radiators. This should translate to a higher COP, since this decreases quickly with increasing temperature difference between source and delivery media. Is this indeed the case in practice?
                                            #864386
                                              Thanks to Robert and Adrian however … My interest in Air-to-Air systems has been revived!
                                              I may be able to install one of these units in the Dormer, by replacing half of the window on the ‘half-landing’ of the stairs.
                                              Grateful for any thoughts or links to suppliers.
                                              https://energysavingtrust.org.uk/advice/air-to-air-heat-pumps/
                                              #864395
                                              Robert Atkinson 2
                                                @robertatkinson2
                                                Yes, they have a higher COP.
                                                The modern units also use Brushless DC (BLDC) motors or VFDs. They often call it “inverter” technology. This means they can vary the compressor delivery depending on demand rather than the older On/Off  systems where it ran flat out  for part of the time. This increases efficiency and reduces noise. Importantly you don’t get sudden increase / decrease in noise of the old ones when they cycled.
                                                #864397
                                                Robert Atkinson 2
                                                  @robertatkinson2
                                                  That link only talks about the self contained units which have placement restrictions. The traditional types with the compressor outside and small bore refrigerant pipe work are more flexible. You can get low level indoor unit not much bigger than a radiator, high wall mounted ones and “cassettes” that fit into the ceiling.
                                                  I used Mitsubishi in my last place and Daikin here. The last place was a self-install before the F-Gas regulations came in. I already had proper vacuum pump, gauges etc.
                                                  Robert.
                                                  #864398
                                                  Vic
                                                    @vic
                                                    Just as a point of interest. I picked the brains of an acquaintance last year about Air Conditioning as until very recently he was a consultant in the industry. One thing he mentioned was not to forget you can use AC units for heating as well as cooling. He said his own use at home is 80% heating 20% cooling. The installer also mentioned the cost advantage of using our AC unit for heating over our GCH. We only have the AC in our lounge but we have used it for heating a couple of times. Now we have solar panels and a home battery we may try using it a bit more.
                                                    #864403
                                                      Thanks, Robert
                                                      For context … I could just add this to my recent posts:
                                                      The window in my Dormer is unnecessarily large … it spans almost  the full  width of the two half-staircases, and is generously high
                                                      A quick check with the Disto shows 1681w  x 1589h internally
                                                      Given that the “view” is mostly the slate roof of the adjacent converted-chapel, I could probably sacrifice 50% to a monobloc heat-pump, directing the warm air down the stairs and letting it rise naturally throughout the building.
                                                      Yes … the house is very small
                                                      P.S. … I already have an electric shower, and could happily manage with instantaneous heaters for the sink and washbasin
