Piston rings
Piston rings
Home › Forums › General Questions › Piston rings
  • #837113
    Dougie Swan
      @dougieswan43463
      hi
      Im looking for some piston rings 1-3/16 dia
      width around 1/16, can anyone help
      Dougie
      #837118
      Andrew Tinsley
        @andrewtinsley63637
        They are not difficult to make, what little skill is needed comes in splitting them. I have a large number of US and UK made spark ignition engines which often need new rings.
        Andrew.
        #837128
          I also make them myself
          If you have not made the cylinder yet then 30mm rings are readily available on the net and only 6thou smaller.
          #837136
          ChrisLH
            @chrislh
            Prof Denis Chaddock wrote a very informative article on the subject of DIY piston rings many years ago. PM me if you would like a copy.
            #837149
            duncan webster 1
              @duncanwebster1
              Good article by TDWalshaw (Tubal Cain), again pm me for copy
              #837166
              Dougie Swan
                @dougieswan43463
                Thanks for the replies, Jason came up with the best suggestion
                30mm it is
                Dougie
                #837167
                  At £2.80 a pair delivered, that is a lot less than the cost of a suitable piece of CI bar which means the “weed Whacker” ready made rings do have a lot going for them.
                  Though I tend to use Viton O rings in my IC engins these days.
                  #837266
                  bernard towers
                    @bernardtowers37738
                    lots of articles available on ring making/tempering etc.. The american ic mags have some interesting info. `i break mine first and gap later after tempering. Try to get SG bar.
