Rotary valve engine
Rotary valve engine
Home Forums Work In Progress and completed items Rotary valve engine
Viewing 2 posts - 1 through 2 (of 2 total)
  • #803358
    AStroud
      @astroud
      Hi all
      Here is a clip of my rotary valve steam engine, inspired by the River Queen plans. I made several changes, not least to the rotary valve design as in my mind the published plans only allow partial opening during the cycle.
      https://youtu.be/gVItba_ImAM
      #803369
      John Haine
        @johnhaine32865
        Partial opening during the cycle is probably preferred especially for high speed running as it admits a burst of steam into the cylinder which is then allowed to expand doing work.  Reduces steam consumption.  Engines often have variable cutoff valve gear to optimise efficiency over a wide range of speeds.
