Metal Lathe Centering Roller Tool for chucked item
Home › Forums › Hints And Tips for model engineers › Metal Lathe Centering Roller Tool for chucked item
  • #737432
    Blue Heeler
      @blueheeler
      A simple idea how I quickly center up small pieces of offcuts. Not saying this is how anyone else should do it, but it works accurately for most of the work that I do. It doesn’t replace your Mitutoyo dial indicator for super accurate work, but as I say in the video its quick and easy.
      Hope it helps someone out.
      https://www.youtube.com/watch?v=GfoSqPa0zgQ&t=228s
      #737439
      Fulmen
        @fulmen
        The quick and lazy method is to chuck it lightly, run it in reverse and just use the cutter.
        #737445
        Clive Foster
          @clivefoster55965
          Thanks for the video link.
          I’ve got one lying around in the “what does it do” drawer in the workshop. Came in the big boxes of stuff parked next to the scrapyard find P&W. Shop made with obvious care so/ I kept it assuming that one day I’d find out what it did.
          Decade later I now know.
          #737455
          Bo’sun
            @bosun58570
            Works well on the circumference too.
            #737464
              I’ve got one of them too. Made from a smaller roller bearing bolted to the end of a bit of 3/8″ square key steel. Dead simples but works magic on both face and diameter. Much quicker than faffing about with washer chucks or parallel spacers etc for face truing. Not one of those things I use all that often but dead handy when I do.
              #737497
              Vic
                @vic
                I’ve been using one for a couple of years now. It does come in handy sometimes.
                #737507
                Ian P
                  @ianp
                  Instant destruction of the tool tip if its carbide!
                  Ian P
                  #737573
                  Blue Heeler
                    @blueheeler
                    I use mine on a daily basis as I’m always using small bits and pieces (those bit and pieces all of us never throw away).
                    #737680
                    Macolm
                      @macolm
                      If you have a 2 station QCTP, just use the blank end of any suitable tool in the other station.
                      #737683
                      Fulmen
                        @fulmen
                        Ian P
                        Not at all. But You have to use veeeery little clamping force, barely enough to hold the part still. And I probably wouldn’t do it with a high rake insert.
                        #775383
                        Trevor Howley
                          @trevorhowley19606
                          I’ve used this myself for a couple of years ,works ok .
                          #782928
                          Trevor Howley
                            @trevorhowley19606
                            I’ve also used for a couple of years , works a treat .
