crank journal
crank journal
Home › Forums › I/C Engines › crank journal
  • #715663
    bricky
      @bricky
      Is stainless steel acceptable for a crank journal with phospher bronze bushes on the crank.
      #715724
      duncan webster 1
        @duncanwebster1
        As no one else is chipping in, here’s my two pennorrh. You’d have been better using leaded bronze for the bush. Phos bronze is harder, so for bearings it’s better to use a hardened shaft. However if you’re not going to run it much you’ll probably get away with un- hardened, but what grade of stainless are we talking about?
        #715725
        Harry Wilkes
          @harrywilkes58467
          Bricky
          I can’t fully answer your question but when I was making a new crank for my 3″ Burrell I was advised against using stainless steel
          H
          #715729
          duncan webster 1
            @duncanwebster1
            Perhaps we should find out what material pair the navy are using on their aircraft carrier prop shafts , and then use something else
            #715733
            bricky
              @bricky
              I don’t know the grade of stainless but I am using up the stainless I obtained from a friends workshop ,if not advisable I will use silver steel instead and I will obtain some leaded bronze for the bushes.Tahnk you both for replying.
              #716034
                I think that the problem with stainless steel is that it is not so tolerant where fatigue loading occurs.
                It was always important to ensure that stainless car exhaust systems were not stressed when fitted (i.e. mountings correctly aligned). The DC stress of misalignment with the AC stress of vibration can bring the loads to the fatigue stress limit in one direction, leading to failure.
              Home › Forums › I/C Engines › Topics
