Curious Myford Stand
Home › Forums › Manual machine tools › Curious Myford Stand
  • #714265
    William Chitham
      @williamchitham75949
      I saw this Myford on a curious stand in a recent auction, I wonder if it was a factory option?
      Myford
      #714271
        Not a Myford option that I’ve seen but several between wars lathes were supplied on single foot stands. Normally heavy cast iron and probably meant for bolting down.
        #714297
        noel shelley
          @noelshelley55608
          Not seen that type before and UNLESS bolted down I would be affraid it would topple over. Noel.
          #714356
          Nigel Graham 2
            @nigelgraham2
            Aha! Not the strange stand but my eye was also caught by that tailstock chuck….
            I have a couple of what look the same type, with a (Jacobs???) female taper instead of a Morse taper shank. What I take to be the trade-mark rather weakly stamped on the specimen immediately to hand is “Crown”, below a faint, stylised image of the head-gear.
            The jaws are not cone segments but consist of two sets of interleaved plates with a Vee-notch in each so they enclose a square.
            Are these drill-chucks or tap-holders? Or both?
            #714366
              The drill chuck is just an old style 2-jaw but is a drill chuck. We had a thread on here a while back – several makes including Drummond.
              #714379
              peak4
                @peak4
                There’s been a couple of threads mentioning them; This is One
                I’ve a couple, but they both have jaws more suited to hex or round, though there are versions available designed for square tooling. I’ve not managed to find one yet.
                Bill
                #714575
                  An unusaul stand, topped by what seems to be an early ML4, judged by the flat belt?
                  One careful owner, pity the subsequent one(s) weren’t
                  #714580
                  William Chitham
                    Maybe the new owner will giv eit some love, sold for £65.
                    William.
                    #714624
                    Nigel Graham 2
                      @nigelgraham2
                      Hopefully, yes he will!
                      Thank you for the remarks on the chuck: since the jaws in mine are effectively Vee-blocks they will hold round and square tools.
                      The stand is intended to be bolted down: the feet have quite visible holes.
