Propane regulator needle won’t zero
Home › Forums › Help and Assistance! (Offered or Wanted) › Propane regulator needle won’t zero
  • #34146
    Bill Phinn
      @billphinn90025
      #627766
      Bill Phinn
        @billphinn90025
        The regulator pictured was bought new last year and has only been used a handful of times. It is for use on disposable Bernzomatic style gas bottles.
        The problem is that the needle won't return to zero, and wildly erratic readings now result when it is used.
        Does anyone know whether there is a cure for this sort of problem, and if so what?
        #627768
        Paul Lousick
          @paullousick59116
          Dis-assemble gauge and repair if possible or get a new gauge.
          #627773
          KenL
            @kenl
            The most common cause is simply the needle fouling the dial or the glass, easily fixed if the bezel will come off.
            #627774
            Bill Phinn
              @billphinn90025
              Posted by Paul Lousick on 05/01/2023 23:57:01:
              Dis-assemble gauge
              The thin-walled bezel is welded to the body of the gauge, hence, if disassembly takes place, re-assembly won't, at least not with the same bezel and body. The lens is plastic.
              I or get a new gauge.
              They're no longer available from the supplier I bought it from nor from any other supplier in the UK I'm aware of.
              #627775
              Bill Phinn
                @billphinn90025
                Posted by Ken Little on 06/01/2023 00:06:28:
                The needle isn't fouling anything visible to me.
                #627778
                noel shelley
                  @noelshelley55608
                  Unscrew from regulator body and check thread May be 1/8" gas/bsp or 1/4" replace with 0-50psi gauge redilly available in many places. Noel.
                  #627780
                  John Doe 2
                    @johndoe2
                    Maybe a bit of FOD has got into the gauge, which is preventing it returning to zero?
                    I notice it says not to oil it, but could you remove the gauge and alternately apply pressure and vacuum to try to dislodge whatever is causing the jam? Something like a large plastic syringe might do it, with the appropriate tubing and adaptors..
                    #627782
                    Bill Phinn
                      @billphinn90025
                      Noel, I've unscrewed the gauge from the regulator. The thread appears to be M9x1.0 – definitely not BSP 1/8" or 1/4" at any rate.
                      Is there a suitably threaded gauge to fit that out there?
                      John, I'll have a go at blowing and sucking now that the two parts are separated.
                      Thanks to all so far.
                      #627783
                      Bill Phinn
                        @billphinn90025
                        Dis-assemble gauge
                        Overcoming my initial pessimism, I've done some slow but determined prying and managed to get the bezel and lens off. I'll disassemble the guts of the gauge when I next have an hour or two spare. At the moment, if I return the needle to zero with my finger it just springs back to its original position at around 0.5 bar.
                        #627786
                        DiogenesII
                          @diogenesii
                          Maybe (Likely?) NPT – 27tpi?
                          #627788
                          Speedy Builder5
                            @speedybuilder5
                            What pressure are those Bernzomatic bottles at ? Quick search on the net says 228psi. Is the gauge on the bottle side or delivery side. If the gauge has been over pressured, then the Bowden tube may have been deformed.
                            easily done !!
                            #627818
                            Peter Simpson 3
                              @petersimpson3
                              If the Bourdon tube is still intact you will need to pull the needle off the spindle and replace it to zero. I still have a Budenburg pointer lifter lying about the workshop from my Tiffying days.
                              #627828
                              Samsaranda
                                @samsaranda
                                If you reset the pointer to zero how are you going to know whether the gauge is reading the pressure accurately without checking the range on a deadweight tester, I wouldn’t trust the gauge without being able to verify that it is reading accurately. Dave W
                                #627830
                                  Posted by Bill Phinn on 06/01/2023 02:30:53:
                                  Dis-assemble gauge
                                  That's bad news. My limited experience is broken gauges of the basic kind are hard to fix. They're not designed with maintenance in mind, so anything other than a simple problem like the needle fouling the glass, is likely to be difficult to fix. You certainly don't want to do anything that might cause it to leak gas. Worth looking inside, but I fear it will have to be replaced.
                                  Shouldn't be difficult once the thread is identified, unless the existing gauge is a weird shape. It looks ordinary though.
                                  Andrew Tinsley
                                    @andrewtinsley63637
                                    Just not worth tinkering with. Replacement gauges are cheap and plentiful. I am sure making an adapter would be simple enough for a model engineer.
                                    #627844
                                    Nicholas Farr
                                      @nicholasfarr14254
                                      Hi, not what you want to here, but faulty regulators, whether it's the gauges or the regulators no matter how old they are, should be replaced, and if it has gone wrong within in the first year through no fault of your own, the supplier should replace it under guarantee. All portable gas regulators etc. have a life of five years, whether that's in use or sitting on a shelf in a box.
                                      Regards Nick.
                                      #644217
                                      Bill Phinn
                                        @billphinn90025
                                        Just to round this thread off, I got the needle and the dial plate off, and found a spring inside had become displaced from a toothed half-wheel. After a few trial efforts I worked out where the spring was supposed to sit to get the needle resting comfortably back at zero.
                                        I've been using the regulator without problems for a few weeks now, and I'm confident it's reading the way it was designed to. It gives very stable readings and there is certainly no evidence of any leakage in the system anywhere.
                                        I'm not saying this is a permanent fix, nor advising anyone to follow suit if they encounter a similar problem with their own regulator, but given the way my regulator is now behaving and the fact that it has never been over-pressurized I don't think its safety is necessarily any more compromised now than it was as a result of the way it was originally assembled in the factory.
                                        My motivation for saving it was, as I've already said, the fact that this kind of regulator is no longer for sale anywhere in the UK; if someone one knows differently, I'd be pleased to know where.
                                        #644238
                                        Martin Connelly
                                          @martinconnelly55370
                                          I would just point out that the gauge pictured would not have been allowed to be used for pressure testing or on gas equipment where I worked. You were not allowed to use gauges with a hard stop at zero as you could not tell if the gauge was reading zero when depressurised, it may still have pressure in it even when reading zero. Also the hard stop could knock the pointer needle around on its spindle resulting in inaccurate readings. If you get a replacement aim to avoid such gauges for something used with flammable gasses.
                                          Martin C
                                          #644291
                                          Bill Phinn
                                            @billphinn90025
                                            Thanks for the advice, Martin [and to everyone else who's contributed].
                                            It's proved difficult finding a replacement gauge as the thread on mine is M9x1.0.
                                            If anyone knows where I can get one I'll certainly follow that up.
                                            #644303
                                            martin haysom
                                              @martinhaysom48469
                                              Posted by Bill Phinn on 07/05/2023 14:38:30:
                                              could you make an adaptor
                                              #644316
                                              HOWARDT
                                                @howardt
                                                There are gauge suppliers n the UK, a simple search will tell you. It is best to have a word with a knowledgable seller and go with their recommendation. Gauges are supplied to work with different media and flammable gases are just one. Correct pressure range s vital and I believe the working pressure should never be above 3/4 of the gauge range. Usual threads are BSP and NPT, but gas tight adaptors can be supplied were needed.
                                                #644321
                                                Bill Phinn
                                                  @billphinn90025
                                                  Posted by martin haysom on 07/05/2023 16:42:31:
                                                  If it was straightforward and cost-effective for me to do so, I probably could; without a lathe, it might be a bit of a lash-up.
                                                  Posted by HOWARDT on 07/05/2023 19:46:55:
                                                  I've found several, but either they don't advertsie their prices or their gauges aren't at prices I could really justify given the application. I paid £25 for the regulator.
                                                  If you can point me to suppliers who advertise their prices and whose prices are proportionate to the cost of my regulator, I'd certainly appreciate it.
