sluggish running
sluggish running
  • #430010
    David Bothwell 1
      @davidbothwell1
      My locomotive is a piston valved (two and a half inch Pacific) I have had it running (and not) on various sessions, I think the locknuts somehow moved and caused problems. At present the loco is running ( in full forward gear) but only for a short burst and petering out in a sluggish way. Could this be caused by uneven opening of the valves? Any suggestion gratefully accepted!
      #33454
      David Bothwell 1
        @davidbothwell1
        loco runs on air, but sluggish
        #430013
        Nick Clarke 3
          @nickclarke3
          Does the loco seize up and stop or does it just 'run out of puff' with everything still free to turn?
          #430019
          David Bothwell 1
            @davidbothwell1
            Thanks for the reply (Nick) It doesn't seize up just doesn't run as long as it did, Previously the engine has run almost as long as the compressor applied air
            #430030
              'almost' as long? it shouldn't falter if the compressor is supplying air. Unless it is a very very small compressor so the tank runs out.
              It sound like it has something loose, perhaps in the valve gear, that moves out of place and has been getting looser.
              #430039
              David Bothwell 1
                @davidbothwell1
                Thanks for the reply, I will check it out in the morning
