aluminum toothed rim fitted to the divider plate on a tight fit a timing belt and then a smaller timing wheel on the drive servo motor is how to convert your dividing head to bcome a 4th axis drive. By the way I have a few centroid cnc controller fitted machines, 2 Bridgeports, one OKK, One Okegai, One Chinese, one Emco Minimil and one Emco Mini Lathe,and another mini mills of chinese origin. I also have one 25 kw Induction Heater, 60 Kw Induction Heater, 60kw medium frequency melter, and one 100 kw Induction melter. I do make many things and order book full.
I make centrifugal castings of Cylinder Liners, Bushes and all machines made by me. All pictures available on request with no expectations of businesses. This is purely give what I have learned. For example I repair Turbo chargers of any size and the bushes are made of CW713R which you can buy from company called Zabrak Metal, Turkey. The turbos will run for another couple of thousand hours. I can give the gen on it. The thrust bearings can be made of Alu, and thrust plates with MS, case hardened fianlly and polished. Pics available on request.
Further Centrifugal casting pics for vertical axis machine built by me for small bushes in Brass available.
