Solder problems
Solder problems
Home › Forums › Hints And Tips for model engineers › Solder problems
  • #650461
    Margaret Trelawny
      @margarettrelawny34058
      Hello all
      i am having problems soldering a brass tube to a small mild steel frame. I am using TSC A8 stainless steel flux and a small micro torch. I did a test on a small piece of tube soldered to a mild steel washer – but now when I try the same materials on the actual parts – it won’t have it. The solder seems to stick to the steel and also to the brass – but then instantly falls apart so a bond is not being made.
      What am I doing wrong? Both parts are cleaned with emery then 99% isopropyl.
      Is there a better flux or a particular solder you could recommend?
      thanks in advance
      Margaret
      #30831
      Margaret Trelawny
        Brass to mild steel
        #650467
          You don't say what solder you are using
          #650471
          Anonymous
            Whatever the solder the choice of flux seems unusual. The A8 flux is intended for soft soldering stainless steel and hence is quite aggressive, ie, contains acid. For brass to low carbon steel I'd use a low temperature silver solder and EasyFlo flux. Depending upon part size a micro torch won't provide enough heat.
            #650472
            Clive Brown 1
              @clivebrown1
              As per Jason's question, but if it's a lead free soft solde type, then I'd change to tin / lead "electrical type" solder. It wets better. The flux is an aggressive type. I'd use an ordinary, resin type but probably not essential.
              Edited By Clive Brown 1 on 30/06/2023 14:39:46
              #650475
              Margaret Trelawny
                Solved it. I changed the flux to LA’s brass/steel etc flux and it worked.
                sorry for the panic!
                #650477
                Margaret Trelawny
                  Agree Andrew. The flux was the issue. Someone suggested I try that as it worked for them
                  – i thought it strange but tried it.
                  Thanks Jason – the flux change helped the solder flow as it should.
                  I appreciate your time answering guys.
                  all the best
                  Margaret
                  #650478
                  Margaret Trelawny
                    Jason – it’s a ‘general’ solder which came in a pack. It doesn’t actually give it’s content.
                    #650479
                    Dave Halford
                      @davehalford22513
                      'Tin' the steel first before putting the two parts together. I suspect the micro torch does not have enough power, the kitchen hob would be a better supplier of heat.
                      #650494
                      Richard Millington
                        @richardmillington63972
                        I use LA plumbers flux (as I have some from plumbing jobs) works for me. smiley
                        #650519
                        Margaret Trelawny
                          Richard – yes LA Plumber’s flux did the trick and it’s for a vintage puppet solenoid restoration.
                          Dave – the micro torch did the job perfectly. 😊
