turning a large diameter
Home › Forums › General Questions › turning a large diameter
Viewing 25 posts - 1 through 25 (of 44 total)
  • #29361
    david bennett 8
      @davidbennett8
      39″ radius
      #659125
      david bennett 8
        @davidbennett8
        Following a current discussion on the "clocks" forum here, I would welcome .any suggestions on the best way to form a piece of steel, about 2" long by 1/2" wide into a section of a circle with a 39" outside radius. The finish has to be good, at least ground.I have an old Myford lathe.
        dave8
        Edited By david bennett 8 on 04/09/2023 23:57:52
        #659126
        Ady1
          @ady1
          I would start by melting down the lathe
          #659128
          david bennett 8
            @davidbennett8
            Posted by Ady1 on 04/09/2023 23:50:23:
            O.K, I amend my question to "any sensible suggestions"
            dave8
            #659130
            Jeff Dayman
              @jeffdayman43397
              Suggest providing a fully dimensioned sketch with critical parameters and finishes if you want sensible suggestions. Ground finish on a part that is formed metal seems contradictory. " 2" wide x 1/2" thick " describes 2 dimensions – at least three dimensions are needed to describe even the simplest 3D objects.
              #659136
                As Jeff says we really need the 3rd dimension.
                If you hade a 40" length of 2 x 1/2 and needed the radius on the end it would be easy to put a pivot hole at one end and cobble something together so the other end could be swung against a moving tool then a grinding wheel / sanding disc held in the lathe chuck.
                If you need the radius on a shorter piece of metal then it is just a case of mounting it to an arm that can be swung as above
                Also what sort of Section of a circle once the radius is done is it pie shaped or cut along a cord
                Edited By JasonB on 05/09/2023 06:51:41
                #659137
                  Posted by Jeff Dayman on 05/09/2023 03:46:51:
                  Just for clarity, Jeff … he actually wrote: about 2" long by 1/2" wide
                  no mention of thickness
                  Edited By Michael Gilligan on 05/09/2023 06:55:59
                  #659143
                  John Haine
                    @johnhaine32865
                    Cnc mill the profile. Polish by hand. Actually 1 metre approx outside diameter.
                    #659145
                    Ady1
                      @ady1
                      That's why I melted the lathe down, for more metal
                      I suppose you could roll it out into foil to get 39"
                      A ground 1 meter diameter is going to take some doing if we assume a 1/2 by 2 strip, like the outside of a large clock
                      A blacksmiths bar roller and nice shiny chrome coating would be easier
                      Edited By Ady1 on 05/09/2023 08:58:23
                      #659151
                        A much longer piece than necessary, roll it to radius and machine to size (likely sawing and then finish-machining to size).
                        Nearly 2m, in diameter – and only about 50mm long- is not a great deal of change from straight, flat or with a bit of a filed ends?
                        Depending on the surface finish required, maybe even surface grind the section required, before bending – and protect that surface during the bending operation.
                        OOPS. The sector is going to be about a metre long? Just use a linisher for the very slight curved end?
                        Edited By not done it yet on 05/09/2023 09:12:03
                        #659153
                        John Haine
                          @johnhaine32865
                          We don't need a 1 metre dia bit of metal, we need a small bit with a radiused face with 50cm radius of curvature on it, which would need to be about 4cm long. and maybe 6 to 10mm thick. Width behind the curved face wouldn't need to be large, less than 10mm I'd guess.
                          #659157
                            Quite easy really.
                            Solder the target block to the end of a piece of angle iron (just because it is probably a readily available cheap item) that is about 42 ins long.
                            Remove tailstock from lathe and clamp on convenient slab to extend bed so that you have a support point 1m from chuck. Drill the angle iron and seat up pivot point etc.
                            Arrange to camp the angle iron to the cross slide but with some flexibility to control its sideways movement and height across an end mill held in collet/chuck. After rough forming move to a small grindstone.
                            #659160
                            John Haine
                              @johnhaine32865
                              Like this – not to scale. Upper surface 500mm radius, exaggerated width but ~40mm, thickness into page say 10mm. There would be a blind hole in the lower face for a pendulum rod to fit into, probably carbon fibre for minimum mass. Assume the bob is on the lower end of that rod so its CG is 100mm from the top face. Material has to be steel or iron so it can be attracted to the lower face of a strong magnet that will support the bob weight. Within the above limits the amount of material in this needs to be minimised so the pendulum approximates as closely as possible to "simple".
                              Just for information, the reason for the circular arc on the top is so the CG of the bob will swing in a cycloidal path at least up to +/- 10 degrees from vertical.
                              #659162
                              Ady1
                                @ady1
                                Aha!
                                #659163
                                Ady1
                                  @ady1
                                  The amount needing removed is pretty minute
                                  One square is 0.05" (1.27mm)
                                  Edited By Ady1 on 05/09/2023 09:59:24
                                  #659164
                                  John Haine
                                    @johnhaine32865
                                    Exactly.
                                    #659166
                                      One I made earlier
                                      As I said earler clamp/screw your bit of metal to a longer piece that has a pivot hole, provide a pivot which will be approx 500mm from the cutting tool then sanding disc held in the lathe chuck. Simples.
                                      #659169
                                      Ady1
                                        @ady1
                                        Moral of the thread is "ask old guys technical stuff at 9am and not 11.45pm"
                                        #659170
                                          Here you go.
                                          Pivot at far end will need to be something clamped to the bed.
                                          If you put a slot towards the other end to take a pin fitted to a cross slide tee nut then winding the cross slide in and out will move the workpiece on the end of the bar in an arc.
                                          Could also be arranged vertically with the pin that goes into the slot mounted on a vertical slide and the pivot 500mm out to the front of the Myford anyone who has read the Minnie book will know the method as it is the same for the expansion link machining.
                                          PS Younger guys will give an answer before 7.00am
                                          Edited By JasonB on 05/09/2023 10:15:29
                                          Edited By JasonB on 05/09/2023 10:22:10
                                          #659174
                                          Paul Lousick
                                            @paullousick59116
                                              removed
                                            Edited By Paul Lousick on 05/09/2023 10:47:57
                                            #659175
                                            Pete White
                                              @petewhite15172
                                              Posted by Ady1 on 05/09/2023 10:11:05:
                                              Yes but there is a good chance that alot of them will have woken up grumpy lol
                                              Pete
                                              #659177
                                                Posted by JasonB on 05/09/2023 10:14:24:
                                                You mean before going to bed after they get back from clubbing?
                                                BTW this 'long radius' thing is common model engineer practice making expansion links on steam engines.
                                                Edited By Bazyle on 05/09/2023 11:08:23
                                                #659179
                                                Grindstone Cowboy
                                                  @grindstonecowboy
                                                  Pete
                                                  But some of them might let their wives to sleep late
                                                  I'll get me coat…
                                                  Rob
                                                  #659186
                                                  bernard towers
                                                    @bernardtowers37738
                                                    Its 39" RAD chaps
                                                    #659190
                                                      39" makes no real difference to the method I showed, might just need to extend the pivot point out beyond the R?H end of the lathe but that is simple enough.
                                                      All the curves on this bench I made were done in a similar sort of way and radiate out from a single point, from memory the top of the rear rail is 6.5m radius
