Slow setting Epoxy
Slow setting Epoxy
Home Forums General Questions Slow setting Epoxy
  • #629485
    Andrew Tinsley
      @andrewtinsley63637
      My local supplier of slow setting epoxy has stopped stocking this item. Any recommendations for a supplier and indeed a good brand to replace my old stuff.
      Everyone seems to go for quick setting epoxy, which I have never found as good as the 24 hour variety.
      Andrew.
      #29002
      Andrew Tinsley
        @andrewtinsley63637
        #629487
          I have just put the words Araldite Standard in a Google search
          … and would suggest you do the same
          surprise About 1,090,000 results (0.46 seconds)
          Edited By Michael Gilligan on 15/01/2023 13:27:44
          #629500
          Andrew Tinsley
            @andrewtinsley63637
            Thanks Michael I was unaware that Araldite Standard was the 24 hour epoxy. Easy when you know that. So fixed up now.
            Andrew.
            #629543
            Zan
              @zan
              Slow setting epoxy gives 15.6 m hits….
              #629554
              Ian P
                @ianp
                Posted by Zan on 15/01/2023 18:18:55:
                Yes but some of them will be duplicates!
                So it will take a little longer to find the one you wantfrown
                Ian P
                #629736
                old mart
                  @oldmart
                  I found that the standard Araldite, which is the 24 hour paste, is stronger than the fast curing types. Unfortunately it costs about 4 times as much.
                  #629739
                  duncan webster 1
                    @duncanwebster1
                    It sets faster if you warm it up a bit. Forms nicer fillets as well, and some say it's stronger, but I can't comment on that
                    #629740
                    Pete Rimmer
                      @peterimmer30576
                      Get some Araldite 2013. Industrial strength.
                      #629741
                      Rod Renshaw
                        @rodrenshaw28584
                        Old Mart, can that price difference be typical? I have never noticed such a big difference.
                        A quick look on Amazon (Other suppliers are said to be available ) shows Araldite ( other brands are available ) Standard and Rapid at the same price. Is it possible you are comparing epoxy and "Super glue" which I understand are not the same thing?
                        Rod
                        #629745
                        old mart
                          @oldmart
                          I pay about £1.50 for fast epoxy at Proper Job, try getting genuine Araldite that cheap.
                          #629747
                          Rod Renshaw
                            @rodrenshaw28584
                            Old Mart, Interesting!
                            Just looked at the Proper Job, Glastonbury, site. They have rapid at £1.50, as you said, but no standard. I wonder if the price difference is between a generic product and I am not saying there is anything wrong with it, and a (the? ) brand leader rather than between Standard and Rapid?
                            Rod
                            #629748
                            David Davies 8
                              @daviddavies8
                              BSI (Bob Smith Industries) Epoxy gets good write ups in model railway forums (fora?). Different setting times are available and it’s on sale at Fleabay.
                              HTH
                              Martin Hamilton 1
                                @martinhamilton1
                                Araldite original is still one of the best 24hr epoxies you can buy, dont even bother with the fast setting Araldite it is total rubbish in comparison to the 24hr stuff. Another very good slow setting epoxy & should not be over looked, is JB Weld original.
                                #630085
                                Ian P
                                  @ianp
                                  Posted by Martin Hamilton 1 on 18/01/2023 20:24:26:
                                  On seeing the above reference to 'JB Weld Original' I looked online and see there are dozens of different versions of J B Weld (which is something I was not aware of)
                                  I dont have any idea which is the original 'original' but if I was looking for an adhesive I would select the most suitable one for the job in hand, I suspect though that I would eventually end up with a larder full of JB Weld versions I may never need again. My 'original' would be the one I used the first time.
                                  On the forum and in the MEW there are many articles and postings that mention using JB Weld, so which version is being recommended?
                                  Is there one version that suits most workshop purposes? (its a genuine question)
                                  Ian P
                                  #630090
                                  David Caunt
                                    @davidcaunt67674
                                    https://www.hafixs.co.uk/products/profglue/index.html
                                    This is worth considering I've been using this since a visit to Alley Palley over 10 years ago. Not cheap and it does set fairly quickly but I've used it for everything. Do ensure it is drained back before putting the lid on. Found this out the hard way.
                                    bernard towers
                                      @bernardtowers37738
                                      surely that's cyano I thought the thread was epoxy
                                      #630098
                                      samuel heywood
                                        @samuelheywood23031
                                        Probably not quite what you're after but J B weld seems to take forever to cure whenever i use it!~ not quite as advertised but worth the curing time wait.
                                        Good stuff.
                                        The car wing mirror has held onto the plastic mount for 6 years & counting, not bad for a temporary repair, bonded to plastic.
                                        #630101
                                        Roderick Jenkins
                                          @roderickjenkins93242
                                          Posted by Ian P on 18/01/2023 20:56:33:
                                          "JB weld-original cold weld steel reinforced epoxy" is the one you want. If I don't need the extreme heat resistance and grey colour then the original (blue) Araldite is as strong for domestic purposes. Remember that in all gluing situations, good surface preparation gives the best bond. Our adhesive specialists at work used to glue PTFE components together with Araldite. Mind you, they had to etch the surfaces with Hydrfluoric Acid surprise
                                          Rod
                                          #630120
                                          Lee Rogers
                                            @leerogers95060
                                            For those tricky to hold jobs spot tack with cyano and build up the epoxy at leisure. Spare specs repair still good 2 years on.
                                            #630122
                                            Speedy Builder5
                                              @speedybuilder5
                                              If you want a metallic mix, scrape some of the dust from the guards off of your grinder and mix it into the epoxy.
                                              Also agree that the epoxy fast cure doesn't have the strength of the 'original' slow cure.
                                              Bob
                                              #630168
                                              Rod Renshaw
                                                @rodrenshaw28584
                                                +1 for Standard Araldite. When I consider how much time and effort I put into making something, or the potential consequences of a repair failing in service, the relatively small cost of a tube of branded glue seems trivial compared to the confidence I feel that the joint will be as good as I can make it. As Duncan said some posts ago, warming the glue makes it a lot easier to mix, and a really though mix is definitely needed with all epoxies. Warming the completed joint ( on a radiator or similar, not with a blowtorch! ) certainly speeds up the setting time and I think it makes the joint stronger.
                                                I suppose if I used a lot of epoxy I would try different generic types until I found one which was cheaper and in which I had accumulated some confidence, but I am only an occasional user.
                                                Rod
