Boiler
Boiler
Home Forums General Questions Boiler
  • #27604
    kevin large
      @kevinlarge76611
      Bioler
      #493439
      kevin large
        @kevinlarge76611
        Hi all I would like to make a simple vertical bioler can anyone point me to where I could get some free plans
        And what would be the best solder to use
        #493443
        Tim Stevens
          @timstevens64731
          An interesting idea – using a bioler instead of the more usual type. But as usual, we might guess that you need a boiler to raise steam for a model – is that correct? Then there will be questions like 'how big' and 'what pressure', as well as 'have you done anything like this before – ie made something that could blow up in your face and take the shed roof with it?'
          Regards, Tim
          #493444
          kevin large
            @kevinlarge76611
            Hi Tim yes it is for steam I have several small steam engines ie Stuart beam etc I've made several small steam engines just simple stuff
            But would now like to make a bioler to run about 60 80 psi vertical about 100mm dia and about 250 high gas heated
            #493445
            David Wasson
              @davidwasson11489
              Slow down Kevin, "bioler". Let's try "boiler".
              #493451
              kevin large
                @kevinlarge76611
                Woops
                #493459
                David Wasson
                  @davidwasson11489
                  No problem, carry on Kevin! ( if you read Tim's post, I think he was initially pulling your leg a bit)
                  #493463
                  Thor 🇳🇴
                    @thor
                    Hi Kevin,
                    There is one free plan of a vertical boiler here, might be a bit smaller than you want.
                    You should also find some build logs here.
                    Thor
                    Edited By Thor on 30/08/2020 18:38:37
                    #493469
                    Clive Brown 1
                      @clivebrown1
                      Longtimes ago ME published a Tubal Cain design and construction series for a 3" vertical boiler. Very simple and satisfying to make with a central flue and 3 water tubes crossing the firebox. My gas-fired example steams at up to 80 psi and runs my Stuart Turner engine nicely. 'Fraid I can't recall the ME issues.
                      #493470
                      David Davies 8
                        @daviddavies8
                        Kevin
                        Tubal Cain's 3 inch boiler is listed as a kit of parts and drawings by AJ Reeves. Possibly this is the one referred to above by Clive Brown.
                        HTH
                        John Purdy
                          @johnpurdy78347
                          Kevin
                          Tubal Cain's 3" test boiler was described in ME 18 Feb "77. I made one and you can see a picture of it, and the GA drawing of it in my album. It steams my ST10 quite well on only 10 PSI or so.
                          Martin Kyte
                            @martinkyte99762
                            Kennions vertical boiler kit is relatively simple to build.
                            Vertical Boiler GLR
                            regards Martin
