4BA or 5BA
4BA or 5BA
Home Forums General Questions 4BA or 5BA
  • #27532
    Garry Coles
      @garrycoles69390
      #487232
      Garry Coles
        @garrycoles69390
        Hi, I'm building the 2in scale D & NY Traction Engine and I want to make the cylinder studs, which the drawings state are 5BA that go into the boiler barrel in phospher bronze. But I can only find PB in 4BA size. Will this one size smaller be OK. There are in total 24 studs.
        Garry
        #487233
          Good news! BA numbers run in reverse, so 4BA (3.6mm) is bigger and stronger than 5BA (3.2mm). Provided there's space to fit bigger studs, should be fine.
          Clive Brown 1
            @clivebrown1
            5 BA is almost exactly 1/8". Plenty of that available if you wish to stay to drawing.
            #487248
            Garry Coles
              @garrycoles69390
              OOPS ! I got the sizes back to front. I meant to say that the drawings say 4BA and I can only find PB in 1/8 5BA size.
              #487249
              Harry Wilkes
                @harrywilkes58467
                Hi Garry dont know if your talking about threaded rod or studs ? Studs are better here's a link
                to 5BA by 1" steel studs if they are of use to you
                H
                #487255
                Baz
                  @baz89810
                  Buy some 5/32 or 3/16 diameter bronze and turn it down, should be able to do it in one cut.
                  #487256
                  Brian H
                    @brianh50089
                    I'd be surprised if this company cannot help;
                    Brian
                    #487257
                    duncan webster 1
                      @duncanwebster1
                      If there's room use M4, but the nuts are a tad bigger, so check first
                      #487264
                      Harry Wilkes
                        @harrywilkes58467
                        Posted by Brian H on 23/07/2020 16:58:10:
                        Brian
                        Good suggestion Brian but I think you'll find EKP have reduced the range of studs they used to offer
                        H
                        #487273
                        Garry Coles
                          @garrycoles69390
                          Thanks everyone for your replies. I've already made up some 4BA steel studs but I wanted to use PB to get away from the corrosion of steel to the studs. I was going to use Stainless steel in the beginning, but some one said that's a no go for copper boilers!
                          #487278
                          Harry Wilkes
                            @harrywilkes58467
                            No stainless is not recommended for boiler studs and as far as using PB I would suggest steel is more commonly used
                            H
                            #487291
                            Garry Coles
                              @garrycoles69390
                              Well in the end I think I will stick to using the steel studs I have already. Thanks everyone.
                              #487460
                              Tim Stevens
                                @timstevens64731
                                What is the problem with Stainless for this sort of job, then?
                                Tim
                                #487465
                                Baz
                                  @baz89810
                                  Would have thought that stainless or bronze would be far better than steel, steel rusts doesn’t it?
