Hose thread queery
Hose thread queery
Home Forums General Questions Hose thread queery
  • #485234
    nigel jones 5
      @nigeljones5
      Im looking at a water pump on ebay **LINK**
      the item describes the thread coupling as 2E – hose 20: 2M screw 20 (3/4). Whilst I can make assumptions as to what the thread is can someone in the know please tell exactly what this means in easy speak? Thanks.
      #27510
      nigel jones 5
        @nigeljones5
        #485239
        colin vercoe
          @colinvercoe57719
          3/4" BSP
          #485267
            Like Colin, BSP would be my first thought., with the OD and pitch to confirm. Europe calls BSP "Gaz"
            #485282
            Paul Lousick
              @paullousick59116
              When I click on the ebay link the description says "Sanso Magnetic Pump PMD-421 with a 3/4" connector (standard Hose Connector). Not as stated above by Fizzy "2E – hose 20: 2M screw 20 (3/4)". ??????
              With the conversion to metric, imperial BSP sizes were rounded up. 3/4" became 20mm
              The European terminology for the use of G (BSPP) and R (BSPT) originated from Germany (G for gas, as it was originally designed for use on gas pipes; R for rohr, meaning pipe.)
              Paul
              #485296
                I like the way he seller has expressed the need for priming the pump. Could we have Please 'google it if unsure' as a banner on this site, even a permanet part of all internet browsers. devil
                #485300
                nigel jones 5
                  @nigeljones5
                  Sure enough I put the wrong link in…..but the words are exactly taken from the link I should have put up……apologies all round.
                  #485322
                  Bo’sun
                    @bosun58570
                    Be wary of thread sizes given by some Far Eastern suppliers. They are not always what they appear to be, and not compatible with European fittings. I speak from experience.
                    I've also experienced issues sealing parallel BSP threads. No flange on the fitting, and no spotface on the pump, just an O-ring that immediately rolled out as the fitting was tightened.
                    #485409
                    Russell Eberhardt
                      @russelleberhardt48058
                      It gets more confusing. Here in France 1/2 in BSP thread is called 21 mm, 3/4 BSP is called either 26 or 27 mm.
                      Note – Colin, 3/4 BSP has thread OD about 33 mm not 20 mm.
                      Russell
                      Edited By Russell Eberhardt on 13/07/2020 15:54:46
                      #485493
                      nigel jones 5
                        @nigeljones5
                        well im none the wiser…just read that it might relate to NPT…..who knows?
                        #485612
                        Russell Eberhardt
                          Posted by fizzy on 13/07/2020 21:04:01:
                          I'm pretty sure that you will find that the 3/4" refers to the OD of the connector and that it will be 1/2" BSP.
                          Russell
                          #486283
                          nigel jones 5
                            @nigeljones5
                            measured od at 26mm which i think makes it 3/4 bsp….s-l1600.jpg
                            #486295
                              NPT uses different pitches, as well as thread form,(60 degrees ) from B S P. (55 degrees )
                              Many seem to differ by just just one pitch over an inch.. The combination renders them non interchangeable .
