Enamel Paint
Enamel Paint
Home Forums General Questions Enamel Paint
  • #27299
    Stephen Follows
      @stephenfollows82099
      #465463
      Stephen Follows
        Does anyone have experience of using revel enamels with an airbrush?
        I thin my paint 50/50 but have trouble with second coats dissolving the first. Should I thin less?
        I leave twenty four hours between coats.
        #465473
        Bob Stevenson
          @bobstevenson13909
          It's many years since my airbrush experiences but I think you are using too much solvent and not enough pressure…try experimenting by spraying into a plastic cup… I saw your other post re air reservoir. If your comp does not have one you can experiment by inflating a car spare tyre and tehn connecting the air brush….inflate to 40psi. As ever, a regulator with a conbined moisture trap is more or less essential for any serious airbrush use. All good comps such as the 'Bambi' units come with reservoirs and reg/trap……these units have been, and still are, quite pricey albeit UK made items, however, bambi no do a nice amateur model which is small and silent with decent sized reservoir and comes in at about £100 or less according to supplier/online etc.
          If you look online/youtube there are people putting together their own comps…..Teh Steve Jordan video is probably the best one as he makes wha tis virtually a pro tool using a fridge unit.
          #465487
            What are you thinning it with?
            24hrs can be a bit too long, i've used a couple of paints that state recoat within a few hours but once past 24 you need to leave it several weeks before recoating.
            Edited By JasonB on 18/04/2020 17:41:25
            #465498
            HOWARDT
              @howardt
              Always used to use Humbrol in air brush, thinned down and used multiple coats, allowing to dry sufficiently between coats. Never had any trouble with getting good finish. I can’t remember what I used for thinner, may we’ll have been turps, as I don’t recall buying anything special.
              #465517
              Dave Halford
                @davehalford22513
                White sprit will thin enamel, use as little as you can to get the effect that you want.
                #465588
                Dalboy
                  @dalboy
                  Something else to take into consideration that thinning too much will affect the paint so thin less and if possible change the nozzle size on the airbrush. Some of the cheaper airbrushes don't have this facility
                  #465594
                  Pete Rimmer
                    @peterimmer30576
                    Posted by JasonB on 18/04/2020 16:16:24:
                    The enamel paint I use on my machines is like that. Second coat within 2 hours or leave 6 days otherwise it will trap the solvent in the first coat and could blister.
