Rounding con rods on linisher
Home › Forums › General Questions › Rounding con rods on linisher
  • #338886
    richard 2
      @richard2
      Can any one give me any ideas on rounding the ends of con and coupling rods on a sander?
      I don't have enough brain cells as an oldie to be able to work out some sort of adjustable plate to feed the rod up to the belt.
      Yes, I know it can be done on the mill – but – as a still playing musician I value the ends of my fingers
      Many thanks
      Richard.
      #25787
      richard 2
        @richard2
        #338902
        Alain Foote
          @alainfoote90915
          Suggest you turn a button type guide to locate in the end hole and with the same radius as the end of the coupling rod. You also need to have a table to rest the coupling rod on which is at 90 degrees to the disc or belt.
          #339150
          richard 2
            @richard2
            Thanks Alain
            I have found a device in an American book for use on the the mill which I have put together and does the job very well.
            Richard.
