Wanted 6″ of 7/8″ Tubing
Home › Forums › General Questions › Wanted 6″ of 7/8″ Tubing
  • #189631
    Lionel Titchener
      @lioneltitchener
      Hi,
      I have almost finished putting the Apron back together on my Myford 254.
      Where the lead screw goes through the apron there is a tube that it runs through that is a push fit on the apron housing.
      It's 7/8" outside diameter, with a wall of .036"
      It does not appear in the Myford parts list for the apron.
      Has anyone got a piece of 7/8" DOM tube that has a good surface finish that can be used to make a new tube?
      The old part has perforated and lets the oil out.
      Thanks.
      #23877
      Lionel Titchener
        @lioneltitchener
        #189634
        Nick_G
          @nick_g
          Is the Myford working.?
          Is there a good reason why you could therefore not make one.?
          Nick
          #189636
          Lionel Titchener
            @lioneltitchener
            Saddle off the Myford, so hoping to get a piece of tube that can be cut to size and cleaned up with a bit of fine emery paper and made to fit.
            Headstock is on so can spin the chuck, but cannot turn anything from the toolpost.
            Looking at the old part the bore looks smooth, may be a weld mark so could be welded tubing, so I'm hoping that it was fabricated with off the shelf tubing.
            #189640
            Tim Stevens
              @timstevens64731
              If it is any help, proper british motor bicycles had 7/8 diameter o/d handlebars. Bit thick, perhaps, but a start?
              Tim
              #189641
              Lionel Titchener
                @lioneltitchener
                Thanks Tim, have a few old handlebars around here, as you say a bit on the thick side.
                Trying to find a bit of 7/8" x 20g tube, Have an old mop handle, but the wall is too thin, and outside diameter a bit of a loose fit.
                The outside diameter is 7/8" (.875" ) and the lead screw is .750" With wall of .036" have a clearance of .053" so have .0265" clearance around the leadscrew.
                Been searching to see if it matches a Reynolds size but have not found anything yet.
                I would have thought Myfords bought an off the shelf standard size, as it looks like a length of tubing with no machining marks.
                Edited By JasonB on 12/05/2015 19:06:26
                #189643
                Lionel Titchener
                  @lioneltitchener
                  No idea where the smiley came from????
                  #189644
                  KWIL
                    @kwil
                    GLKennion sell 7/8" x 0.036 brass tube
                    #189652
                      Posted by Lionel Titchener on 12/05/2015 17:05:20:
                      I'm afraid it's a "feature" of this forum
                      Innocent punctuation gets interpreted as stupid smiley things.
                        But easily correctedsmiley
                        #189656
                        Brian Wood
                          @brianwood45127
                          Lionel,
                          I have a length I can spare, salvaged from a ladder radiator. It is seam welded steel tube, wall thickness 0.048 inches of nominal O/D at 7/8 inch.
                          Send me a PM with your address and I'll post it for £2 to cover that.
                          Brian
                          #189726
                          Lionel Titchener
                            @lioneltitchener
                            PM sent to Brian Wood, have also ordered a length of brass from the company that Kwil suggested, have a couple of options now.
                            Thanks all.
