Pillar drill running in reverse
Home Forums Workshop Tools and Tooling Pillar drill running in reverse
  • #474560
    michael howarth 1
      @michaelhowarth1
      I have just spoken to my son in Canada. He bought a S/H pillar drill (make SA LR 102902-6) about a year ago and has only just started using it but it runs anticlockwise. It seems to be a straightforward pillar drill with an induction motor and no reversing facility. What could be wrong with it please ?
      Mick
      #19773
      michael howarth 1
        @michaelhowarth1
        #474566
        Martin Connelly
          @martinconnelly55370
          It probably has a start capacitor and run capacitor. If so it could be start capacitor open circuit or missing. Centrifugal start switch for the start capacitor stuck open circuit. Broken wire in the start capacitor circuit.
          These are not in any special order. The start capacitor starts the motor going in the correct direction then is disconnected when the machine is up to speed.
          Martin C
          #474608
          old mart
            @oldmart
            A photo of the wiring going into the motor would help, if I'm right, just swapping the correct two wires might do the trick.
            #474623
            michael howarth 1
              @michaelhowarth1
              Thanks gents. I will try and get some photos to post.
              Mick
              #474627
              John Baron
                @johnbaron31275
                Hi Guys,
                I've had that, a stuck open CF switch ! The motor starting in different directions at random.
                #474636
                Mike Poole
                  @mikepoole82104
                  Try spinning it by hand in the correct direction and then start it while spinning, if it runs in the right direction then the start circuit is u/s as mentioned above.
