Should have stayed on the sofa today
Home Forums Workshop Tools and Tooling Should have stayed on the sofa today
  • This topic has 13 replies, 11 voices, and was last updated 9 May 2020 at 22:00 by not done it yet.
  • #470182
    Ian McVickers
      @ianmcvickers56553
      Well a while ago I ordered some lathe tool holders from ebay and they arrived and fitted without ant issues so decided to order some more from the same person but they never arrived. Ordered some from someone else and they all got taken to work to be re-machined because none of them were the same dimensions and only one of them fitted the tool post.
      Anyway decided from now on to make my own. Machined the lump of steel to the dimension required and cut the slot near to size ready for the dovetails. Dont have a dovetail cutter so decied to make one. Everything was going really well, or so I thought, right up to when I was going to fit it in the mill for a test cut then realised my mistake.
      Hopefully I`ll cut the next one the right way.
      #19739
      Ian McVickers
        @ianmcvickers56553
        #470186
        Ian Parkin
          @ianparkin39383
          Just run your mill in reverse?
          #470188
          duncan webster 1
            @duncanwebster1
            So can't you just run the spindle backwards?
            #470191
            Steviegtr
              @steviegtr
              I have made a few myself. Interesting. I did cut one a tad too wide. I watched tubal caine doing one last night & he used 2 dowels to get the width correct. Never thought of it myself. If I had I would not have errored. Good luck.
              Steve.
              #470194
              Ian McVickers
                @ianmcvickers56553
                Unfortunately my mill doesnt run in reverse. Standard single phase drive.
                #470203
                Henry Brown
                  @henrybrown95529
                  Ian, if I put my SX4 into tapping mode I can run the spindle backwards, just a thought as I only realised this after having the machine for nearly twelve months…
                  #470209
                    All good practice
                    #470216
                    Jeff Dayman
                      @jeffdayman43397
                      Sell your special one on Ebay to fund making your new one.
                      I can see the ad now :
                      RARE HANDMADE SPECIAL ANTI-HYSTERESIS CUTTER
                      Attributed to I. McVickers, artist in residence at "The Shed", in his 'Tools For Resistive Materials' Phase.
                      One of a kind industrial process artefact.
                      Valued at 1850 UK pounds, now offered without reserve at 1125 UK pounds.
                      (NOTE only the first 500 offers will be entertained)
                      What do you think? (Yes I have been working with marketing twats too long)
                      #470235
                      Anonymous
                        Posted by Jeff Dayman on 08/05/2020 20:50:22:
                        smile
                        #470245
                        Phil P
                          @philp
                          Looks perfectly OK to me devil
                          Phil
                          #470353
                          Kiwi Bloke
                            @kiwibloke62605
                            Oh, thank goodness – I'm not alone! I thought my ability to carefully, and with great deliberation, make something completely – and I mean completely – wrong was unique. Do you think there are any more of us out there? Anyone?
                            Nice bit of work, though. It just needs to be rotated in a fourth spatial dimension (if you can find one), and all will be as intended.
                            [edit because of sub-total SNAFU]
                            Edited By Kiwi Bloke on 09/05/2020 12:48:52
                            #470452
                            Ian McVickers
                              @ianmcvickers56553
                              Nice one Phil, have you been watching This Old Tony? Jeff if you can sell it for £1125 Ill give you 50%.
                              New one made today.
                              Kiwi Bloke, its amazing what you can come up with when you put your mind to it.
                              #470476
                                Making left- and right-handed parts has been my downfall before now – even after carefully noting to myself that the parts must made different after the initial shaping!
