Life is more diffcult than it initially looks.
You will need to regrind of all mating surfaces as well, eg saddle and tailstock, corresponding gib strips etc.
This can be done in Mytholmroyd (where whatever is left out of Myford is located) but if you are located in Poland as your surname suggests, your option is to find a fitter who may undertake rescrapping it for a reasonable money.
Have you managed to get bedways and mating surfaces rescrapped, your machine will be superior to any ground product, possibly better than new.
IMO doing any scraping job on surface under headstock is of no use, but if you go for grinding, by all means do it as well. You will possibly need to reallign headstock with bedways after all this job. There is a lot of mythology around about supposed difficulties in doing so. Contrary to all of that I have found this task quite straightforward. You will get there with set of shimming strips, precision level, test turning bar with 2 bobbins 6 inch or so apart, patient measurments and 1-3 days of dedication. Later you may need to reallign crosslide.
I was there in the past. Still tapered socket needs correction and suitable grinding jig to be mounted on crosslide is under construction.
Martin
