Springs for Chuck Jaws
Home › Forums › Workshop Tools and Tooling › Springs for Chuck Jaws
  • #17791
    Stephen Ward 6
      @stephenward6
      #199352
      Stephen Ward 6
        @stephenward6
        Hi Guys
        Could anybody please advise me where I can purchase some chuck jaws springs. I am in the process of refurbishing a small German made breast drill and one of the springs is missing. I have Googled and only been able find references about these springs in the US.
        The od is 3.64mm
        the length is 16 mm
        #199359
        Michael Cox 1
          @michaelcox1
          Try ball point pens or disposable lighters. These are full of small springs that might be suitable.
          #199372
          steamdave
            @steamdave
            Old computer printers and copying machines are another source of springs, along with many other goodies.
            The Emerald Isle
            #199378
            Clive Foster
              @clivefoster55965
              Had a similar problem with the centralsing chuck from a Pollard tapping attachment. I'm pretty sure that the return springs out of empty air freshener aerosol cans turned out to be sufficiently close to the right size. Maybe after cutting down to length.
              Clive.
              #199385
                The springs need to be all the same to keep it in balance which an odd one won' t do. But the actual strength is less important. I suggest you look for a new long spring that has the necessary outer diameter and cut it in 3.
                #199399
                Boiler Bri
                  @boilerbri
                  Try "kato entex" in Google.
                  Bri
                  #199404
                  Stephen Ward 6
                    @stephenward6
                    Thanks guys for your input you given a few options that I will try – Much appreciated.
                    Stephen
                    #199425
                    john carruthers
                      @johncarruthers46255
                      Exactly what I was doing last week, refurbing my old Stanley enclosed hand drill. I ended up buying a cheapo chuck from Machine Mart just for the springs.
                      Worth a fiver if I get another 40 years out of it.
                        Hello Steve
                        I would buy a cheap drill at a boot sale and scavenge the springs.
                        Ian S C
                          @iansc
                          It is possible to straighten, and rewind the spring from a ball point pen(the one I tried), I used a nail for a mandrel, I wound it in a close form then stretched it.
                          Ian S C
                          #199451
                          JohnF
                            @johnf59703
                            Stephen please look at your messages.
