Forming round heads on small steel rivets.
Home Forums Workshop Techniques Forming round heads on small steel rivets.
Viewing 25 posts - 1 through 25 (of 30 total)
  • #15863
    Ken Bevan
      @kenbevan42381
      #248475
      Ken Bevan
        @kenbevan42381
        Is there a special technique for forming the round-head on small steel rivets. I have tried by attempting to peen over the rivet but have not met with the success I would like, especially when the rivets are in close proximity to one-another; maybe it's a matter of technique. Any advice would be appreciated.
        #248479
        Zebethyal
          @zebethyal
          last time I used any round head rivets, I made use of some rivet punches, one to protect the pre-formed head and one to form the cut end after initial peening over.
          #248482
          maurice bennie
            @mauricebennie99556
            Hi Ken , There is a tool called a rivet snap ,various sizes. It looks like an oval punch with a semi circular dome hole and a drilled hole beside it to match the size of rivet .Have a set of them . Maurice.
            #248483
            maurice bennie
              @mauricebennie99556
              Hi again Ken google rivet snap , lots of info.Maurice
              #248485
              Zebethyal
                @zebethyal
                They are about £7.00 each from RDG tools and other similar suppliers:
                #248487
                  Ideally you want two of those snaps. One goes into the bench vice so the factory head of the rivit sits in the half round recess.
                  You then place your work pieces onto the rivit and "Set" them using the plain hole in a second snap, this will make sure the work pieces are pushed close together and that they seat right against the factory rivit head.
                  Depending on rivit size you now place the rounded hole of the second snap onto the rivit shank and hammer it down, larger rivits may benifit from some hammer work first.
                  Allow approx 1.5 x diameter of rivit protruding to form the head
                  Personally I prefer separate round snaps and sets, if you are not carful with the oval ones they can mark the surface if not held perfectly perpendicular to the work. The set can easily be made by drilling a hole in a bit of rod, does not really even have to be hardened.
                  Edited By JasonB on 29/07/2016 10:50:50
                  #248505
                  Speedy Builder5
                    @speedybuilder5
                    Are your rivets annealed ? Some steel rivets have worked hardened in manufacture making it a bit harder to set them (especially smaller ones). Also try to set the rivet with minimum number of hits – again work hardening. They say mild steel doesn't harden – I agree to differ. If all else failed, could you use copper ?
                    BobH
                    #248506
                      Posted by Speedy Builder5 on 29/07/2016 12:13:15:
                      … They say mild steel doesn't harden – I agree to differ…
                      "They" haven't done much sheet metal shaping or panel beating then have they.
                      #248510
                      Ajohnw
                        @ajohnw51620
                        I have used that sort of snap at work – use a decent sized hammer and not lots of blows. The protruding length of the rivet needs to be correct for the shape of the snap. One underneath for the head and another to hit with the hammer as Jason suggests. I thought that rivets were usually annealed.
                        surprise I still have an engineers hammer. It's a good deal heavier than a typical wood working type and has a ball end as well.
                        Ken Bevan
                          @kenbevan42381
                          Thanks for all the quick responses to my request.;lots of helpful info. I am riveting the tender beams on a model GWR loco & want the round heads on the reverse side too.Have previously riveted flush on the back of a 'Tich' I built & so have no experience of forming the round heads on the other side. Will try Jason's suggestion re: Home-made snaps because of the close proximity of the rivets in clusters-will report back after a few practice runs.
                          Ken
                          #248523
                            When things get a bit tight you have to resort to modifying the snaps, as you can see some of these have been ground down so they can fit up close to an edge
                            #248535
                            Ken Bevan
                              @kenbevan42381
                              Thanks Jason – the advice & pics. are really helpful.
                              #248562
                              Bob Brown 1
                                @bobbrown1
                                I made my own snaps using a ball nose milling cutter in some silver steel as the space around the rivet was quite tight.
                                #248570
                                  If possible, use the pre-formed head on the outside so if the heads you are making aren't perfect it doesn't show up so much.
                                  julian atkins
                                    @julianatkins58923
                                    I would echo previous comments about new supply not being soft iron rivets.
                                    I always add a sprinkling of fine brass file swarf onto the rivet snap that the preformed head sits in, before belting the other end.
                                    Cheers,
                                    Julian
                                    #248606
                                    Ken Bevan
                                      @kenbevan42381
                                      Thanks to you all for your helpful advice, tips & comments – they've really been most helpful in pointing me in the right direction to success. The advice from Julian re: the use of fine brass filings works in raising the snap sufficiently to avoid marking the work – most grateful to you all!
                                      Ken
                                      #248746
                                      John Ockleshaw 1
                                        @johnockleshaw1
                                        Hello Ken, I think it was the late W.J.Hughes who recommended using three hollow punches to form rivet heads.
                                        The sketch shows their proportions. They limit random buckling of the shank and offset heads.rivet head.jpg
                                        #248751
                                        Ken Bevan
                                          @kenbevan42381
                                          Thanks for the detailed drawings John. I have made up some 'sets' as per previous suggestions in the thread so far, & have met with very good success compared to my previous attempts. Would like to make up a set like you suggest but how could I achieve the dimensions attained, particularly in diagram 2, in the home workshop?
                                          Ken
                                          #248753
                                          hth
                                            @hth
                                            Never done it myself but . A ball peen hammer was commonly used to preform the rivet head , you hit the edges of the protruding shank with the hammer and then finish it off with the snap.
                                            #248756
                                            John Ockleshaw 1
                                              @johnockleshaw1
                                              Hello Ken, I use D bits to form the cavities. Machine the taper on and hand file the radius on the second punch's D bit. For the third one hand file that as well if you do not have a ball turning tool.
                                              One other thing – machine say a 5 deg. chamfer on the face of the punch leaving say a 0.020" land around the opening. This will save marking your workpiece if the punch is not perfectly plumb.
                                              Best wishes, John
                                              #287332
                                              Dean Dehghan-Khalaji
                                                @deandehghan-khalaji54664
                                                Thanks John, for those drawings this has helped me a lot. Thanks Ken for asking the question smiley
                                                #287344
                                                Perko7
                                                  @perko7
                                                  I found a large-ish nail punch at the local hardware shop which had a hollow point that was just the right size for rounding the heads of 5/16" steel rivets. Used a piece of 6mm plate on the anvil with some depressions made with a ball-shaped cutter in the mini-tool to support the work and the 'back-side' of the rivet while shaping the top. Made a number of depressions at various spacings so that adjacent rivets already set did not stop the next one from bedding down nicely. Found it a bit hard to support both the work and the rivet punch in one hand while wielding the hammer in the other, so the flat plate came in quite useful.
                                                  #287357
                                                  Marcus Bowman
                                                    @marcusbowman28936
                                                    Once you have seated the rivet, if you make the free length of shank protruding beyond the material (the part you will punch to make the head) between 1.25 and 1.5 times the diameter of the shank. That will allow you enough material to form the head. Less than 1.25 x dia is too little to form a complete hemisphere, and more than 1.5 x dia is too much, which results in the bit nearest the plate/sheet being squashed out, like a fungus at the bottom of a mushroom.
                                                    The previous advice to use the pre-formed heads on the outside is good, but not always possible.
                                                    Pliers-style manual snap tools used to be available from a chap called Dave Noble, but seem not to have been obtainable for some years. There was a good design in MEW or ME some time ago, and I think Model Engineers Laser does the laser cut parts.. The trouble is the operating head is quite large and needs to be able to fit behind the rivet. There is also an air powered tool commonly called a crocodile (or alligator?) which squeezes rivets closed, forming a flat head or a mushroom head, depending on the anvils fitted to the tool. I have one of those tools, but, again, it is usually too large or has too short a throat to fit where I want to rivet.
                                                    Marcus
                                                    #287379
                                                    John Chapman 5
                                                      @johnchapman5
                                                      I restore vintage Austin's there are many parts that are riveted together, Austin used 3/16 steel rivets using a rivet snap was hard work. What I did was make a snap that would fit my air hammer this worked out very well, when using an air hammer wear ear protection as a must.
