Warco 712 Bandsaw
Warco 712 Bandsaw
Home › Forums › Manual machine tools › Warco 712 Bandsaw
  • #14215
    richard perrin
      @richardperrin87256
      #537776
      richard perrin
        @richardperrin87256
        Hi, Am contemplating buying the Warco 712 Bandsaw, fed up with my old Axminster 6 x 4, have any of you purchased this machine, your thoughts and ideas would be very helpful.
        Richard
        #537788
          My thoughts.
          At that price point it should be good.
          I expect there are other suppliers selling that same machine – just cloned with different paint and likely a different price?
          What makes you fed up with your present machine?
          Was it better at first, than now?
          Will this one go the same way?
          Maybe a decent/proper overhaul/repair might be a cheaper, but satisfactory, option?
          Society is too much ‘throw away and buy new’ these days.
          Are you intending to scrap your machine or sell it on to a possible unsuspecting buyer?
          More than enough of my thoughts. I’ll stop here.
          #537798
          Jim Nic
            @jimnic
            That's a heck of a lot of money for a hobby bandsaw. You haven't said to what uses the saw will be put so may be you need a machine of that nature. I have the Warco 41/2 inch saw currently available for £325 and from a lot of other suppliers at varying prices.
            I find it to be a more than adequate size for my modelling needs and with a bimetal blade from Tuffsaws plenty fast and accurate enough.
            Jim
            #537810
            ega
              @ega
              Is there any reason to think that the essential components of the 712 are any better (or worse) than those of the cheaper Warco models?
              Let's hope it will soon be possible to visit Warco et al and see such machines working!
              #537812
              noel shelley
                @noelshelley55608
                Many buget bandsaws are dumped for lack of careful setting up when wear starts to make then inaccurate or the guide bearings get slack. I have been given 2 over the years and all they needed was some TLC and a good blade. Do you really need a new saw ? Noel.
                #537815
                  My 4 1/2 Warco saw was not particularly good. When the tinplate bearing spacer ruined the lower bearing and oil seal on the shaft, after replacing the damaged bits, some time was spent checking, cleaning up and adjusting things.
                  Noel's advice to adjust everything carefully is good.
                  After mine had been set up, it was probably a never to be repeated event, but a trial cut of about 1/16" measured 0.001" difference in thickness.
                  But overall, it was greatly improved, and no longer cuts in an arc.
                  Having set the tension with a Tension Meter, ( to the Jacques Maurel design ) it cuts well, straight, and blades seem to wear out rather than breaking.
                  #537824
                  larry phelan 1
                    @larryphelan1
                    For that kind of money, I,d be looking for more than a bandsaw for hobby use !!!!!!surprise
                    #537829
                    Gray62
                      @gray62
                      Posted by Howard Lewis on 03/04/2021 12:56:06:
                      Hi Howard, do you have a reference for the tension meter design?
                      regards
                      Gray
                      #537832
                      Zan
                        @zan
                        My band saw came years ago from Graham engineering (I think. Or was it excel?) Reduced price at the end of Harrogate The blade carrier arms are of pressed steel rather than the usual casting. Had a few problems, the angled saw carrier wasn’t square and had to be bushed and rebored , it took a lot of attempts to get it to cut straight, but now with the addition of a piece of angle bolted in line with the fixed jaw I can cut very small stuff and even recently did a vertical cut in aluminium 8” long, it went straight down the line leaving it perfectly square n parallel. They just take time to set up. I am thinking of adding a dash pot but. It works ok , used virtually every day now it’s in the extended workshop and not in the garage and there’s always more interesting stuff to do…..
                        the Warco is very expensive my Bridgeport cost less……
                        Edited By Zan on 03/04/2021 13:50:42
                        #537839
                        John Baron
                          @johnbaron31275
                          Hi Guys,
                          Having acquired a damaged 6X4 bandsaw and completely refurbished it for very little money, its a machine that with a little care and careful adjustment I wouldn't be without. So I wholeheartedly agree that they are machines that are worthy of attention. Though the pressed sheet metal frame ones are not worth wasting time on.
                          Machine Mart keep a full range of spares for them.
                          Almost forgot !  You can get an idea of blade tension by tapping the blade with a 8" screwdriver handle.  When its tight enough you can hear it twang.
                          Edited By John Baron on 03/04/2021 14:56:42
                          #537841
                          Andrew Tinsley
                            @andrewtinsley63637
                            I have a an old Graham Engineering 6 x 4 It was awful and was dumped in a corner for years. I then decided to fix it. Now cuts superbly and I am very pleased with it.
                            Just looked up the price of a Warco 712. I don't usually comment, but I am afraid "more money than sense" leaps to mind.
                            Andrew.
                            #537849
                              Gray 62.
                              The Jacques Maurel Tension Meter was published in the June 2016 Issue of Engineering in Miniature, on page 412
                              Basically, the blade needs to be tensioned so that it extends by 0.05 – 0.07mm. I set mine to 0.05 mm.
                              #537882
                              larry phelan 1
                                @larryphelan1
                                Perhaps I was lucky, but my 6×4 Chinese band saw has done all I ever asked of it over the last 20 years, and it has been sorely tested more than once. I think I would look very hard before parting with that kind of money.
                                As another post said, the frames that come with these saws are crap, but it,s easy to build a proper frame, and then it,s all plain sailing. You could buy a lot of kit for that kind of money.wink
                                #537981
                                Brian Wood
                                  @brianwood45127
                                  Maybe I shall get a lot of flak for my thoughts on this thread but isn't it just a bit presumptuous of us to be questioning the OP's reasons behind his request?
                                  He wanted feedback from those with experience of use of a Warco 712 bandsaw, not a barrage of reasons why he shouldn't be thinking of spending his money buying one.
                                  Taking cover now
                                  Brian
                                  #537985
                                    Hi Brian!
                                    Yes agreed.
                                    Not flak, but an explanation?
                                    I gained the impression that the reason for contemplating the purchase was dissatisfaction with a present 6 x 4 bandsaw, so a lot of us chimed in suggesting means whereby it MIGHT be possible to bring the existing machine to an acceptable level of performance, thereby savinng his money.
                                    Please correct me if I am wrong
                                    #537990
                                    Brian Wood
                                      @brianwood45127
                                      Hello Howard,
                                      I can see all the well intentioned reasons why people should respond to Richard's request for views in the way that they have, but I couldn't help feeling that the overall flavour coming over was that we all knew better than him and he should get his Axminster machine to do what it should rather than just dump it.
                                      One such comment was especially close to the bone in my view by even suggesting he might perhaps sell it on to an unsuspecting buyer
                                      He will have his reasons for wanting to make the change and we are entirely wrong to question them, whatever we may personally think.
                                      Brian
                                      Edited By Brian Wood on 04/04/2021 11:09:59
                                      #537999
                                      Jim Nic
                                        @jimnic
                                        The OP asked for thoughts and ideas on the purchase of a particular bandsaw. There have been no responses on that tool to date so I think that offering opinions on how to save a wad of cash on an alternative that many people find adequate could be helpful unless there is an unstated reason why that particular item is necesssary. (Bearing in mind that when I say I need a particular tool what I really mean is that I want it and that is nobody's business but mine.)
                                        Jim
                                        #538109
                                        Guy Lamb
                                          @guylamb68056
                                          When someone asks for peoples opinions on a particular tool/material/process or other, so long as those responses are well meant and honest comments what's the problem? Surely the dissemination of knowledge and opinions is the res on detra of this community.
                                          Guy
                                          #538115
                                          Emgee
                                            @emgee
                                            Most likely Richard also wants the extra capacity (180×300) offered by the 712, but if not like many who have commented I would certainly look at improving the performance of the existing machine before going ahead with another purchase.
                                            Emgee
                                            #538117
                                            ega
                                              @ega
                                              The OP could get the discussion back on track by responding to comments.
                                              I agree that there is a tendency to adopt a "I wouldn't go to Cork from here" attitude.
                                              #538125
                                              Chris Hembry
                                                @chrishembry84309
                                                Can't help directly with the Warco 712, but I have had the Axminster version for several years. It is used for production work cutting up to 50mm hex stainless using Tuffsaws M42 blades. Lost count of the number of cuts it's done but it will be approaching 10k.
                                                Only had two issues: The quick release vice was junk, it wouldn't hold anything after about a week, so a quick rebuild with a trapezoidal screw and brass nut fixed that. Recently, the downfeed cylinder gave up the ghost, but again a quick repair with a new piston and O Ring has transformed it.
                                                I've also had a 6×4 saw for 30+ years, but it just doesn't have the weight on the blade to cut the stainless.
                                                Chris
                                                #538354
                                                richard perrin
                                                  @richardperrin87256
                                                  I asked for a review of the Warco 712 Bandsaw, perhaps i could have phrased the question better, yes i do want the extra capacity, i was expecting some reasoned comments on the machine not the Vitriol shown by some.
                                                  In answer to [not done it yet] as regards the throw away society i drive a 28 year old Volvo, had it from new, how many cars have you thrown away in that time.
                                                  Suggesting that i would pass a dud machine on to an unsuspecting buyer i find quite offensive, don't judge others by your own standards, i could donate it to the local Vicar for slicing cucumber for tea parties.
                                                  Thank you to those of you who did show some support.
                                                  Richard
                                                  #538356
                                                  Andrew Tinsley
                                                    @andrewtinsley63637
                                                    Just shows that you need to specify reasons when you ask a general question.. If you did, then you would get a reasoned response.
                                                    Andrew.
                                                    #538403
                                                      Posted by richard perrin on 06/04/2021 14:32:56:
                                                      Richard
                                                      You asked for thoughts. You might not have even noticed the number of question marks – making them questions, not statements of your intentions. As it happens, i’ve rarely sold on a vehicle – they are used until an uneconomic repair. My present transport is coming up to 25 years old next month and looks like it may well make 30 years without too much expenditure. I don’t know you – you may be rich, I don’t know – but a hobby bandsaw for over a grand (I did think you could look for the same item elsewhere). Who cares anyway, they were just thoughts – except I wrote them down, whereas others didn’t. Do try to be a bit more specific/precise when asking questions is my advice. We’ve all seen the ‘boat anchors’ on ebay from time to time.
