Boxford motor help
Boxford motor help
Home Forums Manual machine tools Boxford motor help
Viewing 25 posts - 1 through 25 (of 39 total)
  • #480987
    Ewan Turnbull
      @ewanturnbull23601
      Hi Folks
      I bought a Boxford Model C lathe but it has a knackered motor – a crompton parkinson 3 phase motor BS Frame no VMA544CM1A, 0.75BHP, 1425RPM
      My question is this….
      I've had a look at a few threads and the question I was going to ask – single or 3 phase – has been answered – (thanks so much for all of these informative posts), 3 phase seems to be the way to go.
      so that moves me on to question 2…..
      can you suggest a suitable direct replacement 3 phase motor that will fit and a cost effective 3 phase converter / VFD
      My electrical knowledge is pretty basic but I'm happy to have a go at stuff with a bit of guidance.
      should I look at a more powerful motor or am i runniung the danger of overpowering the machine and causing damage.
      Thanks in advance for all the help.
      cheers thumbs up
      #13941
      Ewan Turnbull
        @ewanturnbull23601
        Motor replacement advice wanted for a boxford Model C
        #481028
        Dave Halford
          @davehalford22513
          You can use THIS to work out the existing frame size that you have from the bolt spacing. Then buy the same in 3phase as frame sizes are standardised.
          #481032
          Niels Abildgaard
            @nielsabildgaard33719
            My former Boxford A lathe tried different motors and the best by far was a good VFD and a 6 pole 1.1 kW.
            Lathe is protected by the belt drive.If You do something stupid belt slips.
            A short video showing same good VFD plus a four-pole .75kW motor.
            Very nice but 6 pole 1.1kW was better but my space was limited in a new flat after change of home.
            Boxford VFD
            #481038
              As Dave Halford says, first identify the frame (standard sizes for both Imperial and Metric), so the motor will physically fit. Then find a motor in that size, with the wanted volts, power output and RPM. It may be possible to find a VFD & Motor Package, which comes with instructions and simplifies installation – maybe Newton-Tesla. Otherwise the forum is good at answering motor questions.
              A moderately more powerful motor wouldn't do much harm, (say 1HP rather than 0.85HP) but do you really know better than the bloke who designed the lathe? More power puts more stress on the machine all round. It also increases the amount of damage in the event of a crash and the risk of personal injury. Doubling the motor power, or more, is asking for trouble in my opinion, especially if the motor can be over-sped with a VFD as well. Lathes aren't like cars where improved acceleration is a benefit; on a lathe big motors can only do more work faster, which risks thrashing the machine. Big motors on small machines don't produce better finish or improve accuracy. Of course, it's your machine and you can do what you like with it! Chewing metal at high-speed, or delicate precision…
              Have fun!
              Speedy Builder5
                @speedybuilder5
                I have had a Southbend, then an AUD Boxford for 50 plus years 3/4Hp single phase. If you have the money, 3 phase seems to be the way to go, but its only 30 seconds for a belt speed change on mine. Also, there are several posts where the VFD has stopped working – Well its just a matter of more money, I would prefer to spend the money on making things!
                If you were doing a lot of large face work using a powered cross feed, then variable speed would be handy…but how often?
                On the basis that the model C doesn't have powered cross feed I would question the reason why you wanted a VFD ?
                #481046
                Clive Brown 1
                  @clivebrown1
                  Is your lathe an underdrive or a bench model? I've got a bench type ME10. To go the VFD route, I found that the largest frame size motor I could fit without too much surgery of the mounting was a 71. I bought a TEC 0.75kW, 1440 rpm motor from Inverter Drive Supermarket. A 71 frame metric motor will have a 14mm dia. shaft, so the pulley needs to be sleeved You might find an imperial sized motor but prices seem to be higher.
                  If a CUD, can't really advise on motor dimensions.
                  A VFD makes lathe operation much more convenient IMO.
                  Edited By Clive Brown 1 on 20/06/2020 11:32:41
                  #481170
                  Ewan Turnbull
                    @ewanturnbull23601
                    Posted by Dave Halford on 20/06/2020 09:32:54:
                    This is really handy – that was going to be my next question was how do I get a like for like fit
                    cheers
                    #481171
                    Ewan Turnbull
                      @ewanturnbull23601
                      Posted by SillyOldDuffer on 20/06/2020 10:25:21:
                      Have fun!
                      Thanks for this Dave – I was thinking about maybe going up to the 1hp to give it that wee bit more oomph but agree with your point about going silly with power being an accident waiting to happen.thumbs up
                      thanks for the advice
                      #481173
                      Ewan Turnbull
                        @ewanturnbull23601
                        Posted by Speedy Builder5 on 20/06/2020 10:48:21:
                        Hi Speedy
                        to be totally honest – I don't really know. I'm a time served turner and am used to 3 phase but this is just a wee lathe for doing the odd bit of turning at home – mainly motorcycle related and the odd job for a few of my mates that are into steam engines etc. As i'm not looking to use it to earn income I don't really want to spend any more than I need to to get it running reliably – whats the rough price difference between 1 & 3 phase?
                        always good to have a variety of opinions from experienced users.
                        cheers
                        #481174
                        Ewan Turnbull
                          @ewanturnbull23601
                          Posted by Clive Brown 1 on 20/06/2020 11:30:42:
                          Hi Clive
                          it's an underdrive model so space is a bit limited. thanks for the heads up on Inverter drive supermarket
                          cheers
                          #481175
                          Ewan Turnbull
                            @ewanturnbull23601
                            so – these replies have raised another question….
                            2 pole? 4 pole? 6 pole?
                            ?????whats the difference / benefit
                            thanks again
                            Edited By Ewan Turnbull on 20/06/2020 21:29:41
                            #481176
                            Phil Whitley
                              @philwhitley94135
                              remember too that if your VFD outputs 240v 3 phase you will need a motor that can be connected in Delta, but if you go for the VFD with 415 volt output the motor can be run in star. Some modern small motors do not bring the star point into the terminal box, and therefore they cannot be connected in delta.
                              Phil
                              #481177
                              Ewan Turnbull
                                @ewanturnbull23601
                                Posted by Phil Whitley on 20/06/2020 21:29:29:
                                Phil
                                Sorry Phil – I'm showing my woeful lack of knowledge on electrical matters – star / delta? i get your point about being careful to match the VFD output to the motor but is there a difference / benefit to delta over star or vice versa?
                                thanks
                                Ewan
                                Edited By Ewan Turnbull on 20/06/2020 21:32:40
                                #481178
                                Speedy Builder5
                                  @speedybuilder5
                                  Unless you happen to have 3 phase at your workshop, then the single phase motor installation is much cheaper. Going the VFD route, you need both the VFD and a 3 phase motor, and like I said, VFDs come with their own problems.
                                  #481181
                                  Harry Wilkes
                                    @harrywilkes58467
                                    Roughly 2 pl 3000 4pl 1500 6pl 1000 RPM any new motor you buy should be marked 415/240 volts star is 415v delta is 240v
                                    when using a 240v inverter the motor needs to be wired for 240v
                                    If you buy from a supplier of inveter/motors you will get the correct motor but you will need to check it's wired in delta
                                    Hope this helps
                                    H
                                    #481856
                                    Ewan Turnbull
                                      @ewanturnbull23601
                                      Posted by Harry Wilkes on 20/06/2020 21:57:19:
                                      Hope this helps
                                      H
                                      Hi Harry
                                      ideal explanation – simple and to the point
                                      informed is always better
                                      cheers
                                      E
                                      #481861
                                      Andrew Tinsley
                                        @andrewtinsley63637
                                        If going the VFD route, then it is worth putting in a more powerful motor, if it will fit. The reason being that at lower RPM the torque available is reduced with a VFD.. Putting in a more powerful motor returns the torque to a higher figure.
                                        Andrew.
                                        #481865
                                          Posted by Speedy Builder5 on 20/06/2020 21:34:07:
                                          Problems or not, my lathe and mills run on 3 phase motors controlled by VFDs. Much preferred to single phase.
                                          That is currently four VFDs – and this is despite two machines already having (working) mechanical speed variators.
                                          Personally, I’ve had only minor problems while setting up VFDs to control my machines. Improvements in operation, IMO, far outweigh the (fairly minimal) extra cost of a motor with VFD. Soft start, variable speed selection, easy reversal of direction (if required/permitted), reduced vibration, less risk of repairs (start/run capacitors, ‘centrifugal’ start winding switches, etc).
                                          For machines with belt-position speed changes, that is much reduced as likely at least three positions can usually be accommodated with the belt in the middle position.
                                          To be honest, I can’t think of any scenario where a single phase motor is actually better than a 3 phase installation with VFD.
                                          #481870
                                          Speedy Builder5
                                            @speedybuilder5
                                            Just an aside, if the Op doesn't know an awful lot about 3 phase, 440 volts etc etc, perhaps remind him that it CAN be a more lethal combination, more so than the standard 240 volts. Sure 3 phase VFD gives a smother ride and any variable speed can be selected, but for a casual user, the extra money for a 3 phase system would be better spent on tooling in my book. Its the old chestnut comparing a Myford to any other lathe – there isn't an answer. Its what fits your pocket and what is available when you go to purchase.
                                            Ps,  Search This Site for VFD and look at all 96 entries – quite a few failures there !
                                            Edited By Speedy Builder5 on 24/06/2020 11:22:13
                                            #481893
                                              Speedy,
                                              I looked in and expected to see you posting an advantage (even If only just one) of a single phase motor.🙂
                                              I expect most of those failures were of VFDs fitted where single phase motors had already given up the ghost (again).
                                              VFDs are getting cheaper and cheaper. Some may fail but not many three phase motors are reported as failures. It will soon cost more for a decent start capacitor (for a single phase motor) than replacing a VFD.
                                              If I were buying a second hand motor, I know which I would be more confident of it working satisfactorily…. particularly If the frame size was not an important factor.
                                              #481959
                                              Ewan Turnbull
                                                @ewanturnbull23601
                                                Posted by Andrew Tinsley on 24/06/2020 10:57:49:
                                                Andrew.
                                                Hmm that was one of my concerns
                                                cheers
                                                #481965
                                                Ewan Turnbull
                                                  @ewanturnbull23601
                                                  So – time to give the full backstory
                                                  I have a wee workshop beside my garage which I use for woodwork – having a combined workshop in the garage wasn't good – wood don't like engine oil and engines don't like sawdust!
                                                  I have a 3 phase converter which i originally had running my wadkin bursgreen bandsaw and my Union Graduate lathe. Both ran great but I got a bit fed up changing the connection and settings on the converter every time I wanted to work the 'other' machine. One day a friend offered to add some weird gizmo -that I now know to be a VFD – to my woodlathe to allow it to be fed straight from the 240v supply. Ideal said I, after he told me about the variable speed etc.
                                                  However….. when roughing or turning larger dia wood blanks – specially out of balance blanks the woodlathe has to be run at fairly low RPM and it just doesn't have anywhere near the torque it had before the conversion and it kind of spoiled my experience to the point that I avoided woodturning for a good couple of years.
                                                  Spring forward to current times and I am looking to get a system that will work my Boxford in the way it's meant to be used…….
                                                  I was right on the point of ordering a 3 phase + VFD when Speedy made his point about the reliability of VFD's and the cost of replacement.
                                                  I'm happy to spend a wee bit more – looked at the website recommended earlier and its around £200 – £220 for the complete 3 phase system with VFD – if it will give me the best solution.
                                                  There does seem to be an argument for single phase from a cost point of view although as previously mentioned – I'm a bit clueless in this area and don't really know what else I need, do I just buy a motor (££?) and pop that in and it works or do I need other gubbins and have to rework switches etc?
                                                  I'm still leaning towards the 3 phase but want to make sure if I do go that route that I get a reliable VFD . I'm also really enjoying all these different points of view and appreciate all the advice folks are giving. I'm happy to take the time and listen to folks to make sure I opt for the best all round solution
                                                  thanks again
                                                  ewan
                                                  #481966
                                                  Ewan Turnbull
                                                    @ewanturnbull23601
                                                    Andrew.
                                                    Hi Andrew
                                                    would a jump from 4 pole 3/4HP to 4 pole 1HP be enough to overcome the torque problem?
                                                    cheers
                                                    ewan
                                                    #481970
                                                    Clive Brown 1
                                                      @clivebrown1
                                                      The 1 hp motor will always have more grunt at whatever speed, but hobby lathes are rarely taxed to the limit of motor power or torque.The beauty of the VFD is to give conveniently rapid speed control for the large majority of jobs. Don't forget that on the, probably, rare occasions that you do need lots of low-speed torque, the lathe pulley system and back -gear can always be used just as they would have been with the original, fixed speed motor.
