MAKING QC TOOL HOLDERS
Home › Forums › Manual machine tools › MAKING QC TOOL HOLDERS
  • #261129
    RICHARD GREEN 2
      @richardgreen2
      A while back I bought off ebay a "Rapid Original" QC tool post for my Boxford ME10 lathe, it came with one tool holder.
      I thought it would be a nice project to make some more, I decided to make four more, here is a photographic record of how I did it,
      The block as bought,
      I had some steel offcuts, 3" x 1 1/2"x 2" in stock, the tool holder I had was, 3" x 1 1/4" x 1 3/4", so I used the Elliott 14 M shaper to reduce the blocks to size.
      Then I had to machine the main part of large "T" into the back of the blocks, for this I used a 1" endmill in the TOS FA3A mill
      Next I had to machine the "T" of the T slot with a 1"Dia x 1/4" Woodruff cutter, Each side of the "T" was cut in one pass, , 0.145" deep, at 250 RPM and a table feed of 20mm a minute.
      Cutting the second side,
      Now to cut the "V" slots, to start I cut two slots 0.093" wide into the blocks 0.300" deep, x 2.437" apart centre to centre, this was to give the points of the "V" cutter an easier life, I used a 4" x 0.093" slitting saw in a Tom Senior M1 horizontal mill.
      Then I cut the "V" slots on the same machine using a 90 degree horizontal cutter,
      After a bit of tidying up, I then machined the large slot for the lathe tool to clamp into, using a 3/4" 3 flute slot drill,
      Opening out the slot to 0.850" wide x 0.550" deep
      Next I made the height adjusters from 7/8" Dia, steel, with a straight knurl, threaded 8mm,
      Here are the 4 adjusters completed,
      Here are the four tool holders ,assembled , with 6mm tool holding screws,
      This was a nice engineering project, that will make the Boxford lathe a lot more pleasant to use.
      I am quite a shaper fan, I think it would be fun to produce one of these tool holders entirely using a shaper, ( not drilling the holes of course ),
      Richard.
      Edited By RICHARD GREEN 2 on 14/10/2016 20:04:48
      #12787
      RICHARD GREEN 2
        @richardgreen2
        #261137
        Vic
          @vic
          Very nice job Richard. Nothing more satisfying making your own tooling. wink
          #261143
          Chris Evans 6
            @chrisevans6
            Gosh I could do with some of your kit, jobs like that are easier on a horizontal mill.
            #261146
            Fatgadgi
              @fatgadgi
              Richard – thanks for posting the photos … brilliant job. Really.
              I've been thinking about having a bash at making them as well, but have not really come up with a method that I was happy with. Your way is great and it's the 90 deg horizontal cutter that's the clever bit for me – I only have vertical mills, so I never thought of that. But I could make an arbor and hold the cutter in the vertical mill and end up with the same result.
              So I'd better back to the Fosse Way before it finishes …..
              Cheers – Will
              #261152
              Steve Pavey
                @stevepavey65865
                Very nice – especially the straight knurl on the adjusters which, for some reason, always looks more professional to me.
                I'd like to make some more toolholders myself, but It's not so straightforward with a Multifix..sad
                #261189
                Old Elan
                  @oldelan
                  Planning a production run, Richard?
                  I could do with a few more…
                  wink
                  #261218
                  RICHARD GREEN 2
                    @richardgreen2
                    Posted by Old Elan on 15/10/2016 09:41:50:
                    wink
                    Hello Old Elan.
                    No plans for a production run, It was the enjoyment of making my own.
                    Richard.
                    #261219
                    RICHARD GREEN 2
                      @richardgreen2
                      Posted by Steve Pavey on 14/10/2016 22:10:26:
                      Hello Steve, I like the straight knurl as well.
                      Richard.
                      #261220
                      RICHARD GREEN 2
                        @richardgreen2
                        Posted by Will Bells on 14/10/2016 21:34:28:
                        Cheers – Will
                        Hello Will, If you had a vertical mill that you could tilt the head over to 45 degrees, you could cut the 90 degree V's with an end mill.
                        I used the 90 degree horizontal milling cutter, as I found it in a box of cutters I have had in stock for years,
                        The only cutter I had to buy was the Woodruff cutter.
                        Richard.
                        #263395
                        sean logie
                          @seanlogie69385
                          Nice job on the QC tool holders .
                          #263399
                          MW
                            @mw27036
                            Posted by Chris Evans 6 on 14/10/2016 20:54:49:
                            I can only agree with that, nice job, i could do with a few more holders myself and this write up certainly inspires confidence to have a go. yes
                            Michael W
                            #263408
                            RICHARD GREEN 2
                              @richardgreen2
                              Thank you all for your comments, I hope this has inspired some of you to have a go,
                              It's not that difficult, and you have something really practical that you can use at the end of it.
                              And you can make as many as you like, once you are set up for it.
                              If anyone makes any I would be interested to see them.
                              Richard.
                              #263419
                              Douglas Johnston
                                @douglasjohnston98463
                                It's wonderful to see people making their own holders, the only problem is that like women with shoes, the more holders you have the more you want. I had to cheat recently and bought some holders since I don't have enough beefy equipment to make them. The only real advantage in buying them is that they come hardened and nicely ground although they are not cheap.
                                Doug
                                #263447
                                Metalmuncher
                                  @metalmuncher
                                  I made my own QCTH and about twenty tool holders for my S7. Saves a lot of time on a job, much better than the fourway tool post I had. Keith.
                                  #263496
                                    My home made QCTP conveniently uses 1" square material. Tempted to make some aluminium ones and see if they work.
                                    thaiguzzi
                                      @thaiguzzi
                                      Richard,
                                      my Dickson type holders virtually completely done on the shaper in my albums. Nice work by the way.
                                      #272483
                                      MalcB
                                        @malcb52554
                                        If I ever get or make enough room I am going to get a shaper. Its been a long long time since I used one. Taking out having to use it for production purposes must like people say make it a lot of fun and quite enjoyable.
                                        Having to wear clogs though to stop chip penetration in your soles is another issue.
                                        #272484
                                        Speedy Builder5
                                          @speedybuilder5
                                          RICHARD – Do you machine 'dry' as all the swarf looks dry. If not, what coolant do you use?
                                          BobH
                                          #272543
                                          RICHARD GREEN 2
                                            @richardgreen2
                                            Hello Thaiguzzi,
                                            Thanks for the comment, I've looked at your album and you have some lovely pictures of making your tool holders on the shaper……………..Very nice,
                                            Hello Speedy,
                                            I usually machine dry if I can, except for screwcutting, then I use threadcutting oil stuff that I brush on as required,
                                            The two milling machines that I used to make the toolholders both have coolant pumps but neither is connected yet, ( a job for another day ).
                                            I find that using flood coolant only seems to make a mess, and gets in everywhere, also some of the older types of soluble cutting fluid were not that healthy to use, I've got some Rocol stuff now , if I do need any and that has no known hazards,
                                            Richard.
                                            #272600
                                            mechman48
                                              @mechman48
                                              Nice work Richard, & nicely presented.
                                              George.
                                              #272611
                                              peak4
                                                @peak4
                                                Posted by thaiguzzi on 18/12/2016 04:23:06:
                                                Richard,
                                                Thaiguzzi, Arguably to be discussed on another new thread, but having just looked through your toolholder construction photos, is that a Denbigh power hacksaw?
                                                I'd never seen one before, until I bought a part restored one recently. I might have some questions for you when I get round to completing the work and re-assembling it.
                                                Bill (also with a Guzzi, a slightly non standard Mk3 Lemon )
                                                #272742
                                                RICHARD GREEN 2
                                                  @richardgreen2
                                                  Posted by mechman48 on 18/12/2016 19:17:35:
                                                  George.
                                                  Thanks George,
                                                  Richard.
                                                  #273538
                                                  thaiguzzi
                                                    @thaiguzzi
                                                    P4,
                                                    yes, that is a Denbigh. I've had it probably since the late 80's, and it was the only saw in my commercial shop 88-03 back in England. It has done a LOT of work. Still has the flat pulleys and leather drive belt to the saw, and normal vee belt off the single phase motor. It was tired when i bought it, is even more tired now, slop in various bushings, but it just keeps going. Drinks a lot of oil, hydraulics still work, and its a bit like a shaper – wants the oil gun on it all the time. Repainted it dark blue a few years ago, because i felt sorry for her, but mechanically have done virtually nothing to her in over 25 years.
                                                    #273539
                                                    thaiguzzi
                                                      @thaiguzzi
                                                      P4,
                                                      off topic, my 89 Cali III is also very non std. God's Gift to motorcycling was the Moto Guzzi v twin…
                                                      regards,
                                                      Mike.
