GWR Small Prairie 5inch model
Home › Forums › Locomotives › GWR Small Prairie 5inch model
  • #80265
    Stephen Lawson
      @stephenlawson35167
      The Liskeard Model Society have taken on the task of refurbishing a 5 inch gauge GWR 45 class (Small Prairie). Several problems have been solved but one which we are would like some advice on concerns the regulator. It appears to be seized. There is no steam dome as such but the regulator looks to be fitted in the smoke box. Are we right ? How should we go about accessing it ? Is it necessary to remove the superheaters ? Any communication would be appreciated. Regards Steve Lawson
      #1061
      Stephen Lawson
        @stephenlawson35167
        Regulator seized
        #80267
        John Baguley
          @johnbaguley78655
          Hi Steve,
          Is it Firefly to the Martin Evan’s design? If so, the regulator is a simple internal screw down type fitted from the backhead. To remove though you will have to remove the superheaters and the header bush that screws into the front tube plate – the steam pipe from the regulator also screws into this, hence the need to remove it. Have you tried steaming the loco yet? Screw down regulators are notorius for locking up if you let the boiler go cold without opening it slightly. It may free up again when the boiler is hot.
          Stephen Lawson
            @stephenlawson35167
            Many thanks for your reply John. Yes, we think it is Firefly to the Martin Evan’s design. Personally, I am not familiar with “simple internal screw-down” regulator. If anyone is able to supply further info or a reference to location of info I would be very grateful. Drawings would be great but expensive to purchase.
            We have not tried to steam the engine yet, just trying to sort out the obvious problems first. However John, on your recomendation, it would appear the thing to do. Watch this space !
            Thanks again
            Steve
            #80278
            John Baguley
              @johnbaguley78655
              Hi Steve,
              have sent you a pm.
              Stephen Lawson
                @stephenlawson35167
                Please excuse my ignorance John – PM?
                #80293
                John Baguley
                  @johnbaguley78655
                  Hi Steve,
                  ‘personal message’ . When you log on, look in ‘My Messages’
                  Stephen Lawson
                    @stephenlawson35167
                    Figured it out -“eventually”
                    #80310
                    Stephen Lawson
                      @stephenlawson35167
                      For info – John has sent me a copy of article printed in ME dated February 1962. By Martin Evans, the article describes the construction of 5″ Firefly in great detail including working drawings.
                      After mentioning my difficulty to a neighbour, also named John, he came up with a book “Manual of Model Steam Locomotive Construction” by Martin Evans.
                      My cup runneth over !
                      Many thanks John & John
