zyto lathe lead screw
Home › Forums › Help and Assistance! (Offered or Wanted) › zyto lathe lead screw
  • #33197
    Flywheel
      @flywheel
      #352971
      Flywheel
        @flywheel
        Can some kind member of the forum tell me what is the diameter, TPI and thread form of the lead screw that is used on the Zyto lathes – I presume that the same size is used on all the various versions, I also read that the change gears are the same 20 DP as the Myford, can anyone confirm this please, also can anyone tell me the size of the headstock spindle thread?
        Peter
        Edited By Flywheel on 06/05/2018 09:14:31
        Edited By Flywheel on 06/05/2018 09:16:02
        #352978
        Brian Wood
          @brianwood45127
          Peter,
          Have a look at the Zyto material on the Machine Tool archive at http://www.lathes.co.uk where you will find some answers
          The change wheels will all be 20DP 14.5 degree pressure angle and in all probability Myford compatible, there were many Myford look alikes in those days.
