WM18 CNC Mill Conversion
Viewing 21 posts - 1 through 21 (of 21 total)
  • #15189
    Ross Lloyd 1
      @rosslloyd1
      #359866
      Ross Lloyd 1
        @rosslloyd1
        Hi
        Anyone with experience of converting a WM18 mill to CNC know if its needs ballscrews? I have got a quote for a conversion kit but it seems they are suggesting I just use the existing lead screws. Does it not require ballscrews due to the backlash?
        Cheers
        #359880
        Muzzer
          @muzzer
          I don't think you'll find many people advocating use of the std leadscrews. You simply can't make them accurately enough to give acceptable backlash whilst still being able to assemble the nut to the leadscrew. Even if they seem OK when brand new, they will soon bed in and you will have measurable backlash. The friction is also pretty high relative to ballscrews.
          Ballscrews are readily available from AliExpress and ebay for starters. It's one of the first things people usually buy when embarking on a conversion.
          Makes you wonder what else they have cut corners on? Check out the hundreds / thousands of conversions done on similar machines. I assume the generic design used by Warco is available under any number of other brand names.
          Murray
          #359881
            Or read the 2 part article in ME on converting a WM18 to CNC complete with ball screws that has recently been published
            Edited By JasonB on 29/06/2018 13:49:13
            #359897
            Martin Connelly
              @martinconnelly55370
              As well as cutting backlash ball screws reduce the torque required from the motors which gives the choices of smaller motors or higher traverse speed. Also kits mean someone else is making a profit at your expense, it may be worth costing up doing everything yourself. It's not too hard and there are plenty with experience on this forum. The CNC cookbook website also has a lot of useful information for someone starting out in CNC.
              Martin C
              #359910
              richardandtracy
                @richardandtracy
                16mm dia x 5mm pitch x 700mm long ballscrew cost me £35 from China. Thread efficiency 85% compared to 35%, equivalent to more than doubling the motor torque while also almost eliminating backlash. Makes sense to do it.
                It also makes sense to do it yourself – then you know the machine inside-out, which will help if there are problems later.
                Richard.
                #359945
                Ross Lloyd 1
                  @rosslloyd1
                  Posted by JasonB on 29/06/2018 13:40:25:
                  I do have those issues, which is the reason I am asking. It seemed odd to me that the company would not recommend ballscrews, and the replies are confirming their usefulness. If they can be bought cheaply online then thats not a massive issue.
                  #359946
                  Ross Lloyd 1
                    @rosslloyd1
                    Posted by Martin Connelly on 29/06/2018 15:06:36:
                    Martin C
                    Thanks Martin I will have a look at that site
                    #359947
                    Ross Lloyd 1
                      @rosslloyd1
                      Martin C
                      #359949
                      Ross Lloyd 1
                        @rosslloyd1
                        Posted by richardandtracy on 29/06/2018 16:13:05:
                        Richard.
                        Thats quite reasonable. Did you look into 4th axis chucks (not sure if right term) by any chance? £200 seems to be about the going price but I am not sure if that should include a motor or not.
                        #359952
                        Ross Lloyd 1
                          @rosslloyd1
                          Posted by Muzzer on 29/06/2018 13:37:13:
                          Murray
                          Hi Murray!
                          They do sell ballscrews, which again made me wonder. Maybe they were going for a minimal / low cost build, I don't know. This is the full listing:
                          Stepper Motor 8.7Nm Nema34
                          Stepper Motor 4Nm Nema23
                          Digital DSP Stepper Driver 5.6A, 50V CWD556
                          Digital DSP Stepper Driver 7.2A, 80VDC or 60VAC CWD872
                          Breakout board KK01 CNC Stepper Motor 5 Axis with Relay
                          600W PSU 48V 12A CNC Power Supply Stepper Motor Milling
                          £580 inc vat and postage. Good deal or no?
                          Cheers
                          Edited By Ross Lloyd 1 on 29/06/2018 22:59:31
                          #359954
                          John Haine
                            @johnhaine32865
                            Only 2 motors and 2 drivers for a 3 axis machine? Looks a poor deal to me.
                            #359959
                            Emgee
                              @emgee
                              IMO overpriced and likely more power than required for the machine.(8.7Nm)
                              Emgee
                              #359960
                              Ross Lloyd 1
                                @rosslloyd1
                                I missed off the quantities of each. Per line above: 1, 3, 2, 1, 1, 2
                                8.7Nm is for a potential 4th axis
                                smiley
                                Ross
                                #359965
                                Enough!
                                  @enough
                                  Any problems with back-driving of the ballscrews on these conversions?
                                  #359980
                                  John Haine
                                    @johnhaine32865
                                    No!
                                    #359985
                                    Journeyman
                                      @journeyman
                                      MYCNCUK have a few threads on converting this type of mill, which may be of assistance..
                                      John Haine
                                        @johnhaine32865
                                        I built the electronics for my Novamill, BoB + PSU + 4xDM542 drivers (but I've only ever used 3, haven't used A axis yet) for less than £200 buying individual units from eBay. This didn't include the steppers (already fitted to the machine) but Zapp Automation have NEMA23 steppers at up to ~£30 and NEMA34 at ~£60. You may not need a 34 for the Z drive. Lower prices than these available on the web.
                                        #360013
                                        Muzzer
                                          @muzzer
                                          I assume the 4th axis would use a rotary table or similar to achieve a reduction ratio, in which case 8.7Nm must be wonderfully OTT. Calculate what torque would be available at the work and ask what you could possibly need that for. You could destroy significant parts of the machine with that. Even 4Nm for the main axes must have a pretty large safety factor.
                                          One thing to understand about steppers is that their torque falls off rapidly with speed. When I plotted a variety of stepper motor characteristics (torque vs speed), I noted that they display a characteristic that is very close to constant power. What that means in practice is that you might as well drive the ballscrews directly rather than gear the motor down through a reduction stage. That's the most common arrangement for steppers but you do see some with a reduction stage. With the latter you simply reduce the all-important(?) "rapids" whilst doing nothing to increase the torque / force available at a given speed of movement. For a willy waver, the stall torque at the ballscrew might be legendary but if you ever tried to develop it, something would break….
                                          If you spend more money and go for a proper servo motor rather than a stepper, you will find that the stall torque is less than he headline figure for a similar size stepper but generally that torque will be achievable over most of the speed range. So you would probably need a reduction (typically 2 – 2.5 is achievable) but it will achieve much better performance over the whole speed range.
                                          Murray
                                          #360016
                                          Another JohnS
                                            @anotherjohns
                                            I did one of these (but labelled "King Canada&quot using a ball-screw kit from a supplier south of the border here in Canada. Thoughts:
                                            – the underside of the table needed grinding to give more room for the X axis nut;
                                            – the dowel pin holes for the X axis end plates did not match my mill;
                                            – the y axis kit assumed that the threaded holes in the castings were not off-kilter (sigh);
                                            – the gearbox was noisy, so I obtained a belt-drive replacement from benchtop precision in the USA, HUGE difference;
                                            – added ball oilers to all axes;
                                            – I replaced the speed control with direct drive from my CNC bits, and used the tachometer bits to feed back into my CNC computer, to set and hold speed, independent of drive belt setting;
                                            – I added a wired XHC HB-04 pendant – fantastic bit of kit.
                                            Overall results?
                                            The best part was (and is) the LinuxCNC computer code. All I use is a trackball and the pendant, no keyboard in site.
                                            The worst part was the mill – I obviously got one put together from a kit of parts, the table was not flat, but humped down the X axis (could have been because of my slight relief grinding for ball nut) but there are hard spots on the table, and, I think the ways, so the accuracy at some points is debatable.
                                            #360054
                                            Enough!
                                              @enough
                                              Posted by John Alexander Stewart on 30/06/2018 12:43:44:
                                              I did the same on my (BusyBee) version based on your recommendation and I agree. The difference is astounding. I wouldn't mind kitting it out with the Benchtop-Precision 3-ph motor adapter + VFD if I could find a suitable motor locally whose price didn't assume gold-plated windings.
                                              I hope King are better to deal with than BusyBee. When I was looking at fitting ball-screws, I tried to order a spare table and cross-slide from BB (to make it easy and allow me to use the same mill to do the mods) – which they said they were OK with but would have to order from the Far East. They (supposedly) went ahead but in two years I could never pin them down and then they went away completely.
