Who makes Steam pressure gauges reading up to 20 or 30 PSI ?
Home › Forums › Stationary engines › Who makes Steam pressure gauges reading up to 20 or 30 PSI ?
  • #160667
    Brian John
      @brianjohn93961
      I would like to purchase a steam pressure gauge that can read up to about 20 or 30 PSI. Most pressure gauges I have seen go up to about 100 or even 160 PSI. This is not much good if your boiler is only producing somewhere between 5 and 10 PSI.
      #3219
      Brian John
        @brianjohn93961
        I do not want it to read up to 160 PSI !
        #160670
        Ady1
          @ady1
          I'm not a steamie person but at such low pressure would a gauge not be irrelevant?
          Only a simple safety valve would be relevant
          #160672
          Thor 🇳🇴
            @thor
            Hi Brian,
            I believe you can get Mamod 50 PSI steam gauges, a bit higher than you wanted though.
            It seems Reeves have 30 PSI steam gauges.
            Thor
            Edited By Thor on 14/08/2014 12:06:42
            #160689
            Brian John
              @brianjohn93961
              The Reeves 30 PSI gauge looks good.
              Yes, I know it is not necessary but I want one anyway.
              #160696
              Swarf, Mostly!
                @swarfmostly
                Hi there, Brian,
                Do you want the gauge to actually fit to the boiler, i.e. 'model-size', or to use as an item of test gear?
                If the latter, a 'full-size' gauge would do.
                Best regards,
                Swarf, Mostly!
                #160698
                  There's one kind of pressure gauge used on small C)2 and dry powder fire extinguishers that has a spring metal plate inside to extend its reading range. Remove it and it gives a 3/4" diameter guage with about 30 psi FSD.
                  Brian John
                    @brianjohn93961
                    I would like to fit the steam gauge to the boiler once I have built it. I want to have some idea of what pressure is being generated rather than just guessing.
                    #160725
                    Steve Withnell
                      @stevewithnell34426
                      I've got a Stuart steam pressure gauge on my boiler (which has yet to be steamed) but didn't think they were for using for measurement, but rather relying on the safety valve for correct pressure. How accurate are these gauges – +/- 20% of full scale?
                      Steve
                      #162245
                      Brian John
                        @brianjohn93961
                        I have located a couple of 0-30 steam pressure gauges second hand but I am not sure what fitting is on them yet. How would I test them for safety and accuracy ?
                        Edited By Brian John on 31/08/2014 06:43:12
                        #162383
                          Normal practice for steam locos is to test them against a known accurate master gauge, and mark a red line at the safe working pressure – the accuracy at any other pressure isn't critical.
                        Home › Forums › Stationary engines › Topics
