I mentioned this review site in the bridge camera thread. This is a review of the updated FS35.
I mentioned what I have used in the past for point and shoot. This is one of that range.
I've had 3 of them in total and have used them on walks and for social photography. I've never owned an extreme zoom bridge camera with effective focal lengths going up to 1000mm etc so pass on those.
The review site will mention all of the problems that compacts and bridge cameras have but some are better than others and a careful read will give some indication. Sad that it's started using more extreme advertising but it's possible to down load shots taken with the cameras even raw files for those that are interested in that area.
I'm a pixel peeper and feel that cameras should be able to show the images they take at full resolution which means that the image size is considerably bigger than the few mega pixels on a PC screen or even on a small print. I became fed up of carrying a dslr and several lenses about so tried micro 4/3. Much lighter but Olympus keep introducing faster heavier and more expensive lenses for their cameras. However there is nothing really wrong with any of their kit lenses which are all pretty light and easy to carry round in a shoulder bag. I use one from Troop as they are waterproof.
The other thing I found was that ageing eyes was causing problems with cameras that are set up with the rear screen. Some use bigger icons than others which helps but there is still the bright sunlight problem. Some cameras have electronic viewfinders and display all of the information in that. The amount of info varies but take my EM-5 it shows all of it and the camera can be set up as needed via the viewfinder. It also shows directly which area of the image is over or under exposed. Many of the M 4/3 cameras will do all of this. Nikon bought out the 1 range using an even smaller sensor. Good example of them being cowboys at times. They could do all of these things via the viewfinder but don't which has a pretty dramatic effect on the usability of the camera. I find that many shots need exposure compensation and it has to be guessed. I suspect these would have been fairly popular cameras if they had included the right facilities but the dynamic range and noise levels on the sensor aren't that good either. Some compacts might do better.
So I finish up with an E-P3, an EM-5 and an EM-1. I keep the E-M5 as a spare 'cause I wouldn't get much for it if I sold it. The original model is an excellent camera. The new bulkier E-M1 wont ever tempt me so can't see myself ever buying another model.
If it breaks I might be forced to buy Panasonic.
