What is this mic used for?
Home › Forums › Workshop Tools and Tooling › What is this mic used for?
  • #19900
    Charles R
      @charlesr45326
      #489136
      Charles R
        @charlesr45326
        Can anyone shed light on the purpose of this metric Moore and Wright tool?
        Looks like a conventional depth mic but has the scale going in the opposite direction.20200804_121710.jpg
        #489142
        Nicholas Farr
          @nicholasfarr14254
          Hi Charles R, could just be a micrometer head fitted to a custom made block which probably fitted to an instrument or machine for setting procedures. Does it have a number on the thimble?
          Regards Nick.
          #489151
          Clive Brown 1
            @clivebrown1
            Agree with Nick. The standard M&W depth mic. had a rather more shapely block.depth micrometer.jpg
            #489165
            Mike Poole
              @mikepoole82104
              The micrometer parts are available for use on custom jigs etc. They are handy to make into a special purpose mic should you ever develop the need for one.
              #489166
              Clive Foster
                @clivefoster55965
                That style of micrometer head an bock is frequently found on the micrometer adjusted slides / carriers used with optical benches and tables. Usually two counterbored holes to fixt it.
                #489213
                Charles R
                  @charlesr45326
                  Posted by Nicholas Farr on 04/08/2020 12:46:53:
                  Regards Nick.
                  Hi Nick…think you may well be correct and there's no M&W model number on the thimble.
                  #489214
                  Charles R
                    @charlesr45326
                    Posted by Clive Brown 1 on 04/08/2020 13:22:50:
                    Hi Clive…I thought the same myself about the unshapely block, which incidentally measures (exactly) 1/2" in depth.
                    #489215
                    Charles R
                      @charlesr45326
                      Posted by Mike Poole on 04/08/2020 14:00:38:
                      Hi Mike…didn't realise that and thanks for info.
                      #489216
                      Charles R
                        @charlesr45326
                        Posted by Clive Foster on 04/08/2020 14:01:28:
                        Think you may have hit the nail on the head Clive, as there are indeed 2 small counterbored holes in it.
                        #489217
                        Charles R
                          @charlesr45326
                          Also, it's different in that it reads in the opposite direction to a normal depth mic, plus it's only graduated to 13mm.
