What is the SX3 Drawbar thread.
Home Forums General Questions What is the SX3 Drawbar thread.
  • #547558
    Buffer
      @buffer
      Hi
      Does anyone know what the Sieg SX3 drawbar thread is? I have just measured it with only a rule to count the threads and it seems to be 11mm x 1.25 pitch or 0.431 inch x 20tpi which I assume would be 7/16×20.
      Does anyone know what it actually is?
      Thanks
      #28191
      Buffer
        @buffer
        #547560
        Rob Wheatley
          @robwheatley66643
          Think it depends on what collet it is, if it's R8 then it is indeed 7/16
          #547561
          John Haine
            @johnhaine32865
            Is this an R8 version? If so I think it's 7/16 unf.
            Just checked, R8 collet are 7/16 x 20 unf
            Edited By John Haine on 28/05/2021 17:43:35
            #547562
            Peter Cook 6
              @petercook6
              According to the ARC website there are 3 depending on the taper.
              "Drawbars for the SIEG SX3 mill.
              Choice of M12 or 3/8” Whit thread for MT3 spindles or 7/16" UNF thread for R8 spindles."
              #547563
              Bazyle
                @bazyle
                If, somewhat astonishngly you don't have a vernier caliper or a micrometer you may be able to use the mill table and handwheel graduatons to improvise a measuring system, even make a vernier.
                #547572
                Buffer
                  @buffer
                  It's an r8 so the 7/16 then. Thanks for you replies it's all much appreciated.
                  #547573
                  old mart
                    @oldmart
                    Standard for R8 is 7/16 -20 as already mentioned, but I also have one or two R8 tools with metric threads, so I try to check before buying.
