What grade
What grade
Home › Forums › Beginners questions › What grade
Viewing 15 posts - 1 through 15 (of 15 total)
  • #433231
    Harry Wilkes
      @harrywilkes58467
      I've noted on many occasion the wheel hub caps on my 3" Burrell tarnish easily and have copper spots appear on them so I'm thinking that over the winter I may make some new ones, so what's the best grade of brass to use to get a good finish and polish ?
      H
      #9892
      Harry Wilkes
        @harrywilkes58467
        #433240
        pgk pgk
          @pgkpgk17461
          Is it daft to suggest gilding?
          #433279
          Harry Wilkes
            @harrywilkes58467
            Thanks for suggestion but I don't think it would be suitable, correct me if I,m mistaken
            H
            #433281
              gold plating won't tarnish
              #433284
              HOWARDT
                @howardt
                C464 marine grade, will still tarnish but won’t pit.
                #433285
                old mart
                  @oldmart
                  I seem to remember a polish for brass which claimed to extend the life between polishing.
                  #433295
                  Brian Wood
                    @brianwood45127
                    Harry,
                    Why not try a clear varnish after polishing? Rustins made a good one that works well and would save you the effort of making new caps.
                    I agree with you that gold plating might look too bright; it does dull slightly with aging but the process is slow.
                    Edited for punctuation.
                    Edited By Brian Wood on 14/10/2019 15:56:04
                    #433298
                    Grindstone Cowboy
                      @grindstonecowboy
                      I can heartily recommend Renaissance Wax to prevent tarnishing once you have polished them. And for the polishing, I'd go with Solvol Autosol.
                      (Other suppliers are available, it was just the first link I found)
                      Rob
                      #433300
                      pgk pgk
                        @pgkpgk17461
                        Posted by Brian Wood on 14/10/2019 15:55:12:
                        I believe it's possible to get gilding foils in all sorts of metal colours and shades Also many moons ago I dismantled and re-lacquered an ancient saxaphone using cellulose rattle can that was essentailly a clear coat with a tint of brass. Not sure if that's still available (came from an auto paint shop in Uxbridge)
                        pgk
                        #433304
                          The copper spots are appearing because of de-zincification suggesting the hubs are made from an ordinary high zinc brass. This stuff is easy to buy and nice to machine but not good at resisting corrosion.
                          An alternative might be Naval Brass (CZ112) or CZ132, or even a low tin Bronze like Admiralty Brass.
                          Finding someone to sell it in small quantities may be tricky. My quick web search only found people set up to sell to industry. Dunno how big the hubs are but if there's enough metal in scrap plumbing fittings, they're made of corrosion resistant alloys.
                          David George 1
                            @davidgeorge1
                            You can get naval brass from M-machine metals.
                            David
                            #433426
                            Harry Wilkes
                              @harrywilkes58467
                              Thanks for all the answers, I don't mind a quickly with the Brasso but the copper colored spots on the present one do annoyed me wink
                              H
                              #433434
                              Mick B1
                                @mickb1
                                Harry,
                                Their clear metal lacquer works well for me.
                                #433448
                                  I used Windsor and Newton spray lacquer on the brass parts of this Westone Thunder 1 when I smartened it up. It works well and can be removed with White Spirit, it's meant for protecting artworks and for conservation of articles. The original lacquer came off with meths so may have been shellac.
