What depth concrete base for a workshop extension?
Home › Forums › General Questions › What depth concrete base for a workshop extension?
Viewing 8 posts - 26 through 33 (of 33 total)
  • #362652
    choochoo_baloo
      @choochoo_baloo
      Posted by John McNamara on 17/07/2018 15:11:55:
      I hope the concrete supplier you are using is ISO quality control certified the larger concerns usually are this means the batch quantities should be traceable. Where I live there are a few rather gung ho mini mix operators. I suspect some of them batch by eye or is it by material cost? Best they be avoided.
      J
      Thanks for the explanations John. I was planning on using a well-established local concrete firm who have been going strong for 80+ years. I just noted on their website that:
      …supported with full product conformity and quality assurance certification, covered by BSI Kitemarks, ISO 9001 & 14001 (EMS) and CE Marking as relevant.​
      I also forgot to ask: owing to difficult access, I was planning to also use a pipeline concrete pump. Labour saving aside, when compared to spreading a huge mound, is it much less likely disturb the hardcore + mesh by pouring as the pipeline outlet is slowly dragged across the plot?
      #362653
      peak4
        @peak4
        Posted by Simon0362 on 17/07/2018 17:10:35:
        Bob, I hope they don't float away either but given the local geology and our annual rainfall of less than 18", I don't expect a problem – and the builder has installed several others elsewhere too that are still firmly underground.
        Watch this space though!
        They float in the surrounding concrete when it's being poured. I'm sure your builders know the score; we braced my fibreglass moulded car pit off the roof rafters to keep it in place during the pour, which was in several stages.
        I hope you're considering forced ventilation, at least for the one with the paint and solvents in. Ideally for the wine cellar as well in case any welding gasses etc accumulate there.
        Good luck with the build; Here's mine
        Bill
        p.s. Note the concrete delivery wagon; it comes dry and is mixed on site, thus you only need to buy as much as is needed, and the mix can be adjusted according to temperature and required curing time.
        Edited By peak4 on 17/07/2018 17:36:19
        #362655
        Raymond Anderson
          @raymondanderson34407
          As the workshop is free standing and given the size, you won't need any expansion / contraction joints , not on that floor size. If it is a brick / block construction then you will need foundations [ not the floor slab ] and if it is brick / block walls then best to use 25mm insulation around the perimeter of the slab, not only for cold bridging but it also takes up any movement at the interface between the solid walls and the floor slab [ which because they are two different entities, are prone to moving in relation to each other ] Normal concrete strength for a domestic floor slab [ up here ] is 30 newton. and the standard slump is 50. Too much water in the mix has an adverse effect on concrete. The only type that can be watered down to be free flowing is the fibre concrete ie Foundation Flow.
          If it were me, I would go with 30 newton at 150mm depth and the A142 mesh which should be 40- 50mm up from the bottom of the floor slab.
          #362667
          Bazyle
            @bazyle
            The little castles spacers are cute but it isn't clear how high they are. You want the steel 1in from the bottom. It becomes less effective the higher it gets. There are cheaper sources of rebar than TP.
            #362670
            Cornish Jack
              @cornishjack
              Michael Gilligan – I used your link item for our driveway, infilled with pea gravel – very effective in stopping the gravel spreading. Additionally, I used the left-over complete pieces, on their sides, to make a very light, easily supported fence to make the wheely-bins less of an eyesore. So far most pleased and the fence has withstood some distinctly unfriendly North Sea 'attacks'!
              rgds
              Bill
              #362680
                Posted by Cornish Jack on 17/07/2018 18:26:58:
                Michael Gilligan – I used your link item for our driveway, infilled with pea gravel – < etc. >
                Thanks for the useful review, Bill
                peak4
                  @peak4
                  Posted by Michael Gilligan on 17/07/2018 19:00:39:
                  Thanks from me too, you might have just saved me laying a load of slabs behind the new garage.
                  I've already sunk some sleepers to act as an edging, so infilling with this and some gravel might be just the job.
                  When I priced it up elsewhere, it was a lot dearer than this, and they're only just down the road from me a s well.
                  Another Bill
                  #362690
                  Mark Rand
                    @markrand96270
                    A properly designed slab that small won't crack…
                    Ask the suppliers for a retarded load, not a watered load.
