What bearings for a submersible wheelchair?
Home Forums General Questions What bearings for a submersible wheelchair?
Viewing 25 posts - 1 through 25 (of 28 total)
  • #374658
    Gary Wooding
      @garywooding25363
      I have to make a wheelchair to transfer disabled people from the changing rooms to a lift that lowers them, wheelchair and all, into a chlorinated swimming pool. And getrs them out again.
      The real problem is the wheel and caster bearings. Ordinary steel bearings will simply rust, so what bearings should I use. I'm thinking of solid bearings of, say, plastic, brass, or bronze. Nylon is probably unsuitable because it absorbs water, but what about Delrin? It's only about 50mtrs from the changing rooms to the pool. What do the experts recommend?
      Do stainless bearings exist?
      Gary Wooding
        @garywooding25363
        #374661
        Emgee
          @emgee
          Hi Gary
          Would it be possible to use a modified conventional framed chair that could be fixed/clamped in some way to a framed set of castors to transport the people to the pool edge, attach the chair to the lifting device and release the chair to castor frame before lifting the chair over and into the pool.
          This would avoid the need for any bearings to enter the chlorinated water, just a thought.
          Emgee
          #374662
          Senior Yates
            @senioryates
            Hi Gary,
            Try Nylacast I would recommend Aquanyl PA6/12 as it doesn't absorb water. No link to this company but I have used their material many times.
            Good luck
            #374665
            Jeff Dayman
              @jeffdayman43397
              Delrin would be a good material choice I think.
              There are stainless bearings available but unless silicone grease is used, and ALL bearing parts are stainless, there could be issues. I've been stung before with using stainless bearings in a freshwater marine application where the races and balls were stainless but unknown to me, the carrier was plated mild steel. Didn't last long. It was a shock to see orange rust pouring out of that supposedly stainless bearing!
              #374666
              David George 1
                @davidgeorge1
                Have you thought of fitting stainless ball bearings you can get 30 mm x 12 mm x 8 mm bearing for about £10.0 each from simply bearings
                David
                #374672
                  Something like these, nylon races with stainless steel balls, designed for use in harsh environments.
                  (Advantage is needs no lubrication, and you don't want oil/grease in a swimming pool).
                  Edited By Neil Wyatt on 05/10/2018 14:48:21
                  #374673
                  duncan webster 1
                    @duncanwebster1
                    I'd just use Delrin on SS axles. It has very low water absorption and is dead easy to machine
                    #374675
                    David Jupp
                      @davidjupp51506
                      There are also ceramic or ceramic/plastic ball bearings available which wouldn't suffer from corrosion.
                      #374688
                      Tricky
                        @tricky
                        How about lignum vitae as it is water lubricated.
                        #374690
                        mechman48
                          @mechman48
                          Posted by Tricky on 05/10/2018 15:56:41:
                          +1… Plus have you thought about Teflon sleeve bearing … self lubricating & water proof
                          George.
                          #374692
                          Barnaby Wilde
                            @barnabywilde70941
                            I know a little bit about this 'cos I've been doing it since they gave me 12wks probation more than 30yrs ago.
                            The correct answer is to push the chair to poolside & tip the passenger into the pool whilst you both shout "BANZAI".
                            But, that is NOT the PC way to do it & definately NOT the way anyone other than the actual disabled person would want you to do it.
                            To answer your question in the closest way you would want it answering, the chair will be a pool specific one. Either as cheap as chips or a horribly expensive one (depending on the level of corruption in your local SS), so who cares about the lifespan of the wheelbearings? Certainly not the taxpayer, who doesn't get a say in such matters.
                            #374697
                            Nick Taylor 2
                              @nicktaylor2
                              I would opt for plain PTFE bearings, zero maintenance and close tolerances possible without too much friction.
                              #374702
                                No need for lignum vitae or anything home-made. Try searching for 'Waterproof Bearings'. You can get plastic ball bearings specifically designed for low maintenance in wet environments. They're also resistant to most chemicals.
                                I like Mick's BANZAI suggestion, and you should take up his kind offer to be test-pilot. Please video his Kamikazi off the high-board so we can all improve by watching Charity in action.
                                devil
                                Swarf, Mostly!
                                  @swarfmostly
                                  My choice would be a fabric reinforced grade of Tufnol, with the grain going the right way. There used to be a material trade-named 'Ferrobestos' used for propellor shaft stern tube bearings but I guess the 'bestos' bit makes it a No-No nowadays.
                                  On the strength of many years experience, I'd say that metal items don't have to be immersed to suffer corrosion in a chlorinated swimming pool environment.
                                  However, I thought 'the modern thing' with swimming pools was ozone or ultra-violet sterilisation.
                                  Best regards,
                                  Swarf, Mostly!
                                  #374715
                                  HOWARDT
                                    @howardt
                                    Have a word with Igus, very helpful on material selection for their bushes and not expensive. Their catalogue is good if you can navigate your way through it.
                                    #374721
                                    Carl Wilson 4
                                      @carlwilson4
                                      316 stainless steel running in ptfe bush. I have extensive experience of this running in seawater. Lasts forever.
                                      #374722
                                      Howard Lewis
                                        @howardlewis46836
                                        Presumably Staimnless for the shafts and housings, and then a composite, (or could sealed , 2RS, ball races be used?
                                        I liken the suggestion of lignum vitae. Water lubricated, has been used as a thrust bearing for ships propellor shafts for many years. Don't use it as a bouyancy aid, denser that water!
                                        #374724
                                        Carl Wilson 4
                                          @carlwilson4
                                          You don’t need the complication of ball races etc for a submersible application.
                                          #374741
                                          jason udall
                                            @jasonudall57142
                                            Dry bearings would be the way to go.
                                            Because any kind of lubrication will upset risk assessment bods.oil or the hint of a risk of oil ib the pool .Even PTFE built into plastics .. would be called a lubricated solid..just avoid that discussion
                                            So choose a self lubricated solid. Though avoid leaded bronze or similar…
                                            Edited By jason udall on 05/10/2018 21:36:00
                                            #374786
                                            Gary Wooding
                                              @garywooding25363
                                              Thanks for all the good advice. Here's the background to my requirements.
                                              I do voluntary work for the Remap charity (the church-door handrail shown in last month's MEW was one of mine) and neither the swimming club nor the charity can afford to spend much. The hydraulic lift consists of a large platform, level with the side of the pool, which can be lowered into the pool. The wheelchair must be of conventional design so that people with sufficient upper-body strength can propel it themselves. The frame of the wheelchair will be made of PVC pipe and the wheels and casters I have obtained are plastic, but they have conventional steel bearings. There are 12 bearings in all, of three different sizes. Since cost is a major consideration I thought that machining them from solid would be the most cost-effective solution. Delrin or PTFE seem the way to go, but if I could get some lignum vitae at a suitable price….
                                              #374791
                                              Ian S C
                                                @iansc
                                                Lignum Vitae, very old lawn bowls, stick to the plastic bearings on 316 stainless shafts, make sure all metal parts are stainless or plastic, and probably best to over engineer the chair as they can have a rough time from some staff, or patients.
                                                There was a Kiwi bloke Rob Buchanan  making low priced plastic wheel chairs that were suitable for being immersed in salt water. Ron set up a Charitable trust called MEND, I don't know if the e-mail address is still ok,
                                                mend@voyager.co.nz
                                                Ian S C
                                                Edited By Ian S C on 06/10/2018 11:00:26
                                                #374802
                                                Gary Wooding
                                                  @garywooding25363
                                                  Hi Ian, I know such wheelchairs are available in NZ, Australia, and the USA, but apparently not here in UK.
                                                  #374804
                                                    I'm sure you've thought of this, but make sure the tubing is open ended and can drain easily. You don't want it floating away but at the same time you don't want water sitting in it if it's left unused for a week or two.
                                                    john fletcher 1
                                                      @johnfletcher1
                                                      I suggest you contact a REMAP group they are fixing things like this on a regular basis. There is often an a REMAP advert on the inside cover of MEW with contact details. John
