What am I?
What am I?
Home › Forums › The Tea Room › What am I?
Viewing 25 posts - 1 through 25 (of 85 total)
  • #509694
    Jon Lawes
      @jonlawes51698
      I've worked in engineering all my life, primarily aircraft. I've been a model engineer for a few years, but I confess I have no qualifications other than an MoD apprenticeship.
      When discussing hobbies with a colleague I said I was a model engineer. He then pointedly told me that I wasn't any sort of engineer as to be called an engineer I would have had to go to university, or be chartered in some way.
      All my working life I thought I was an engineer (it was in my job title a few times), but it turns out I was misled.
      So what am I?
      Edited By Jon Lawes on 24/11/2020 22:28:42
      #36168
      Jon Lawes
        @jonlawes51698
        #509696
          You are an engineer, John
          … arguably not an ‘Engineer’ but certainly an engineer.
          Nicholas Farr
            @nicholasfarr14254
            Hi Jon, sounds like you are an engineer to me, whatever your colleague says. I was a maintenance engineer for the most part of my working life and I was just classed as a engineer in the last job I had and I've never even stepped into a university let alone attending one.
            Regards Nick.
            #509699
            Martin Kyte
              @martinkyte99762
              You are an engineer, just not a chartered one.
              If it looks like a duck and quacks like a duck . . . . .
              The UK has always had a problem with engineers being under-respected and one of the periodic responses to this is to push mebership of one of the Engineering Institutes. I did an HND followed up by CEI Part2 (honours degree equivalent) which at that time got me associate membership of the IEE usually followed after a few years by full membership. In the end I let my membership lapse as I wasn't really getting anything for the yearly fee apart from the magazine. I can't say I have every really missed it.
              regards Martin
              #509701
              blowlamp
                @blowlamp
                Jon.
                Tell your 'friend' you identify as a transgender model engineer – He won't be able to doubt then. smiley
                Martin.
                Edited By blowlamp on 24/11/2020 22:49:54
                Edited By blowlamp on 24/11/2020 22:51:52
                #509703
                Ramon Wilson
                  @ramonwilson3
                  You stick to your guns Jon – that colleague of yours is doing you and many others a dis- service. If you can only be an 'engineer' by being non artisan then it doesn't say much for most of 'us' does it.
                  ' Course he could just be winding you up wink
                  From a non academic but active 'model' engineer – Ol' Tug
                  #509704
                  Andrew Tinsley
                    @andrewtinsley63637
                    Not impressed by chartered status. I became a chartered engineer early in my career. It was the easiest qualification I ever obtained. So unimpressed by it, that I resigned after a year or two Thought I could spend the annual fees on something more useful!
                    Engineers are way underrated in this country and there seems to be a holier than though attitude by quite a few C Engs !
                    Andrew.
                    #509705
                    mechman48
                      @mechman48
                      In one sense it was correct but those days are long gone. Engineer is a generic term used these days; I never went to uni but have worked in the field as an 'engineer' after being promoted into the role, with all the associated responsibilties, in the Middle east, I don't have a degree just HNC.There are many roles that use the title; auto engineer, computor engineer etc, these can be likened to car mechanic, IT specialist, a plumber is often called a 'heating engineer' I suppose in the realms of having the experience a house wife can be called a domestic engineer, A drain cleaner 'sewage engineer'
                      Nurses these days are expected to get a degree to carry out straight forward nursing,so do we now call them 'Nursing engineers' when back in my youth all they needed to be was SEN & SRN. My progression titles through the business was Apprentice fitter/ turner, journeyman, plant fitter, Marine Engineer ( Jnr & 4th, didn't need a degree for that job ) Maintenance Technician, Snr Specialist Machinist, gas turbine engineer etc. so as far as job titles go.. how long is a piece of string ?. At the end of the day if a Co. advertises a role as '******* engineer' & someone turns up with the best suitabilty / experience for the job, be it he/she is/was a fitter/electrician,technician then in my experience they can be called ***** Engineer
                      George.
                      #509706
                      V8Eng
                        @v8eng
                        Well the guy who comes in the the big tanker to empty our sewerage tanks is an Engineer,  so appointment email informs me anyway.
                        Edited By V8Eng on 24/11/2020 23:34:18
                        #509707
                        Pete Rimmer
                          @peterimmer30576
                          You are what you think you are Jon.
                          Your small-minded colleague sounds like a person with no imagination and precious little charm.
                          #509708
                          Ady1
                            @ady1
                            An engineer is different things at different times
                            In the 30s and 40s an engineer would make his own spares from bar stock etc
                            The engineers I sailed with in the 70s and 80s were spare parts fitters, no-spares meant object-not-working even if a lathe and 2 tons of bar stock were 6 feet away
                            Modern engineering tends to be more academic than the engineers of yore
                            It's such a massive subject, a chap who makes his own small castings and engines has engineering skills while an academic with no such ability could be a fabulous engineering designer
                            The dictionary has a good description
                            a person who designs, builds, or maintains engines, machines, or structures.
                            #509713
                            Jon Lawes
                              @jonlawes51698
                              Its an interesting range of opinions, broadly in line with mine!
                              I think the engineer/Engineer comparison is an interesting one. I can live with being an engineer (lower case e). When I step out of the workshop covered in swarf and oil, smiling at my amateur efforts, I certainly feel like an engineer.
                              Thanks all
                              #509719
                              Clive Hartland
                                @clivehartland94829
                                If you have the ability then you are an Artisan, the high falutin so called engineers with degrees and qualifications are hard put to fix things so pass it down to the Artisan.
                                #509720
                                Old School
                                  @oldschool
                                  According to my local ME club I am not a model engineer because I don’t make and run steam loco’s. But my father was a working clockmaker who made his living making clocks said I was an engineer.
                                  #509721
                                  Brian H
                                    @brianh50089
                                    I'm not aware that Brunel, the Stevensons or Henry Ford went to university!
                                    #509722
                                    Roderick Jenkins
                                      @roderickjenkins93242
                                      Jon,
                                      I'd stick with the Model Engineer description which I'm sure is applicable in your case
                                      "Model" from the Cambridge Dictionary online: "Someone or something that is an extremely good example of its type"
                                      Stay well,
                                      Rod
                                      #509723
                                      Tony Pratt 1
                                        @tonypratt1
                                        'When discussing hobbies with a colleague I said I was a model engineer. He then pointedly told me that I wasn't any sort of engineer as to be called an engineer I would have had to go to university, or be chartered in some way.'
                                        That's just his misinformed opinion.frown
                                        Tony
                                        #509724
                                        Bazyle
                                          @bazyle
                                          Does your method of earning your income define you or your hobby? For most of the population their hobby is going to the pub and watchig football on TV. What are they?
                                          #509726
                                          Swarf, Mostly!
                                            @swarfmostly
                                            Hi there, all,
                                            Either Rolls or Royce (not the financial partner) denied being an 'engineer' – he claimed to be a 'mechanic'.
                                            By the way, I think that in the UK it's an 'Institution' not an 'Institute'. If that matters.
                                            And don't get me going about non-technical managers preferring the advice of an inexperienced colleague with a degree over mine based on lots of experience plus a degree-less C.Eng.!
                                            Best regards,
                                            Swarf, Mostly!
                                            P.S.: Eventually B.Sc. (Hons) Open!!!!!!!
                                            #509728
                                            larry phelan 1
                                              @larryphelan1
                                              Dont know where I fit in ????
                                              Many people have told me what they think I am, but I dont recall any mention of Engineer or engineer !!
                                              But then, when they bring me something to repair, it,s a different story !
                                              So, I dont mind what others say about me, as long as it,s true !!cheeky
                                              #509736
                                              Mick B1
                                                @mickb1
                                                Posted by Pete Rimmer on 24/11/2020 23:33:38:
                                                Quite right. Paper qualifications have only the most casual relationship with actual capability to do the job.
                                                #509739
                                                Martin Connelly
                                                  @martinconnelly55370
                                                  The origin of the word engineer is the same as ingenious. As I understand it to be an engineer is to be ingenious. Some countries do require a degree for someone to call themselves an engineer. I think in Germany they add Ing to their name if they are a qualified engineer.
                                                  So in the UK if you are ingenious you can call yourself an engineer. If you have passed exams and have a certificate I suppose you could call yourself a qualified engineer.
                                                  Martin C
                                                  #509741
                                                  Samsaranda
                                                    @samsaranda
                                                    Our society has changed its values over the years, nowadays there is a government push to put as many youngsters as possible through “University”. This means we have nursing staff who spend time at university and all sorts of other trades now have university degrees, I have a cynical thought that it could be a political ploy to change the real scope of youth unemployment, if the youngsters are at uni for three years when they leave and join the labour market if they are unemployed then they figure as adult unemployed and youth unemployment, that is 17’s plus, is a considerably smaller figure. in respect of whether you are a real Engineer without a uni degree then my opinion is that this a form of snobbery practised by some. I was for a while registered as an “Engineering Technician” entitled to use the the letters Eng Tech after my name, this came about purely because of my work experience as an Engineer and the quality of training courses that I completed during employment, no uni degree. Having a uni degree doesn’t make you an Engineer as I have met many so called Engineers, with degrees, that didn’t know which end of a spanner to hold. If you work with any form of engineering in my book you have the right to use the designation of Engineer.
                                                    Dave W
                                                    #509742
                                                    Nick Wheeler
                                                      @nickwheeler
                                                      Posted by Swarf, Mostly! on 25/11/2020 09:21:48:
                                                      Hi there, all,
                                                      Rolls was the 'financial partner', although Henry Royce was already a successful, wealthy businessman.
                                                      The traditional definition of mechanic was someone who builds, maintains and repairs machinery, which is a better description of what many model-engineers do. Engineer added 'designs' to that list and usually implied some sort of qualification.
                                                      The problem is that meanings in English creep, and so we end up with words being applied willy-nilly and all useful definition is lost. Calling the man who empties a septic tank a 'Sanitation Engineer' is a good example.
