I have a small air brush compressor, with reservoir, bought off eBay quite reasonably, I have run my S10V, Stuart progress, S50, plus small oscillators from it all at approx 3 – 10 psi with no probs apart from the volume requirement, which keeps the compressor kicking in, does get overwarm after prolonged running, only to be expected for these, but it is quiet so no major probs. For the small engines we do, you shouldn't need more than 4 bar . I also have a Clarke ranger which gives me the higher pressure, 116 psi / 8bar & better volume, 24 litre, should I need it, but they are noisy, If you can afford it I would suggest the …
https://www.machinemart.co.uk/p/quiet-run-compressor-2/… usual disclaimer…
I use the blue nylon air line ( 6mm od x 4mm id ) that simply push into fittings & attachments that can be bought easily & cheaply on eBay.
George.
Edited By mechman48 on 30/05/2017 18:29:55
