Water in the Smokebox
Home Forums Locomotives Water in the Smokebox
  • #377822
    Alan maddern
      @alanmaddern76909
      Hi I was wondering if anyone has any Ideas why I have a small amount of water in the smokebox of my 45 xx 5 Inch gauge after steaming? This is a new loco to me, Am I doing anything wrong? Any feed back would be much appreciated! Alan
      Alan maddern
        @alanmaddern76909
        #377825
        Zan
          @zan
          Assuming it has passed the hydraulic boiler test, the source of the leak may be hard to find. Examine carefully and look for telltale white marks on the metalwork. Do not use anything hard to clean the smoke box or you may remove the marks. Check the superheater headers , blower, snifting  valve, exhaust blast steam feed to cylinders it could be any of these.
          Another possibility is that as the engine is new to you, you could be overfilling the boiler and causing it to prime. Good hunting, but how much is ….a small amount of water?….
          Sorry bad spelling from autocorrect
          Edited By Zan on 26/10/2018 19:58:51
          #377827
          Alan maddern
            @alanmaddern76909
            Small amount is approx. a desert spoon full! Yep overfilling the boiler maybe next time I will only fill to a third of a glass instead of half a glass! Thank you for you Ideas Alan
            #377843
            Martin Shaw 1
              @martinshaw1
              Alan
              I suspect this is no more than exhaust condensing on the interior surfaces of the smokebox. I guess your boiler pressure is around 100 psi so it's not very hot to start with and the amount of heat drawn through the tubes is not enough to evaporate it away. I can only speak from experience of the full size item where water definitely indicates a leak, if you have eradicated that possibility then condensation is really the only cause. PS priming is of course a possibility.
              Martin
              Edited By Martin Shaw 1 on 26/10/2018 22:17:30
              #377847
              Alan maddern
                @alanmaddern76909
                Hi Martin, Thank you for your advice! The loco is only around 8 months old it has passed the hydraulic and steam tests no problem, so it is possible its a priming or as you mention a condensation issue (Boiler pressure 80psi) I will check the pipe connections to the Blast pipe and Super heater before I steam her again!
                Thank you again Alan
                #377852
                duncan webster 1
                  @duncanwebster1
                  The flue gasses in the smokebox cannot be colder than the water in the boiler, and at 80psi that is about 160C. Blind guess flue gas 200C. Yes the walls of the smokebox will be cooler, but cool enough to get condensation?
                  #377860
                  Zan
                    @zan
                    Any condensation would be small fry with the heat from the flue gasses which would soon evaporate that. Another thought…. could it be due to condensation in the pipes during cooling down of the engine? Easy to eliminate by checking the s box during a run.  Or try to chock the loco apply the brakes , crack the regulator and examine the s box but take care! Have somebody with a hand on the regulator!
                    Edited By Zan on 27/10/2018 01:22:47
                    #377862
                    not done it yet
                      @notdoneityet
                      Stop guessing. Fill with liquid and test hydraulically. It might not show where it is leaking from, if there is one, but will soon determine if it is a leak, or not. If a leak – start worrying; if no leak – revert to guessing the origin.
                    Home Forums Locomotives Topics
