Vertical milling slide
Home › Forums › Beginners questions › Vertical milling slide
  • #63723
    John Exley
      @johnexley18450
      I would like to purchase a vertical milling slide for the above lathe and wondered what different makes would fit it as there are so many different makes out there can anyone help?
      thanks John
      #5397
      John Exley
        @johnexley18450
        Vertical milling slide for Sieg C1 lathe
        #63733
        The Merry Miller
          @themerrymiller
          It would help to know what the lathe is first John!!
          #63735
          Keith Long
            @keithlong89920
            Since both Axminster and ArcEuro list vertical slides as accessories for the C1 – and they look identical in the catalogues – even the colour – I would think that would be a reasonable starting point. I think you’ll find quite a limited choice that will fit the C1. Most vertical slides on offer are for lathes of about 3 1/2 inch centre height such as the various offerings from Myford, Boxford etc. Provided that the vertical slide you fancy is of a size suitable for your lathe, then the only question will be how to mount it and adaptor plates are easy enough to design and make.
            Keith
            #63736
            Peter G. Shaw
              @peterg-shaw75338
              John,
              Since no-one else has bothered replying, try Arc Euro Trade. They advertise one at £60. Probably plus all the usual addons.
              You could also try the other importers to see if they sell the same or similar lathe, eg Warco, Chester, Amadeal, Axminster (£74.50) etc.
              Peter G. Shaw
              Edited By Peter G. Shaw on 07/02/2011 16:28:04
              #63739
              The Merry Miller
                @themerrymiller
                Posted by The Merry Miller on 07/02/2011 16:03:42:
                Sorry about that John, it’s my eyes you see.
                #63772
                John Exley
                  @johnexley18450
                  Thanks for the reply lads will have a look at arco eurotrade Peter.
                  by the way Merry Miller the lathe type was shown as the thread title have you ant ideas
                  Cheers John
                  #63776
                  Ian S C
                    @iansc
                    If the ones available don’t suit, you could build your own, keep it in the correct propportion for your lathe. Ian S C
                    #63783
                    The Merry Miller
                      @themerrymiller
                      I’d have thought that the vertical slide from Arc Euro at £60 was a good buy john.
