universal pillar tool long arm castings
Home › Forums › Workshop Tools and Tooling › universal pillar tool long arm castings
  • #558237
    YouraT
      @yourat
      Hi.
      Does anyone know of a source for, or perhaps have a spare set of, the castings for the longer arm version of the UPT?
      Hemingway don't do them, and buying them from Martin Model in the US results in some eye watering costs, mainly due to postage charges.
      I've seen a build somewhere which fabricated some using cast pipe fittings, but I thought maybe finding a more local source of the castings might be an easier route….
      Thanks,
      Youra.
      #20414
      YouraT
        @yourat
        #558240
        DiogenesII
          @diogenesii
          Reeves?
          #558247
          YouraT
            @yourat
            Posted by DiogenesII on 14/08/2021 17:38:18:
            Reeves?
            Sadly not….
            #558249
              If you are thinking of building a 6” throat version …
              Why not adapt a bench-top pillar drill ?
              It could be much cheaper, and significantly stiffer.
              Edited By Michael Gilligan on 14/08/2021 19:38:28
              #558250
              Robert Butler
                @robertbutler92161
                This article appeared in MEW, don't know where, don't no when but it did.
                Robert Butler
                #558253
                Mike Poole
                  @mikepoole82104
                  Cast iron square bar could be a substitute, depending on how much trouble you want to go to is could pass for a casting after much work
                  #558270
                  YouraT
                    @yourat
                    Posted by Michael Gilligan on 14/08/2021 19:12:05:
                    I've already built and use the standard version, just occasionally need slightly more reach….
                    #558272
                    YouraT
                      @yourat
                      Posted by Mike Poole on 14/08/2021 19:33:28:
                      Mike,
                      That's actually a smashing idea in this situation, don't really need it to pass for a casting, but might turn away some of the excess between the two ends.
                      #558274
                        Posted by YouraT on 14/08/2021 23:07:51:
                        Aha … I didn’t know that ^^^
                        Nick Wheeler
                          @nickwheeler
                          Why would you make a homemade workshop tool look like a casting??
                          #558310
                          Alan Hopwood
                            @alanhopwood63369
                            When I've made a slightly larger version at work, I've made the column from 30mm en8 and the arms from 1&1/2 X 2 inch steel bar. Mind you, I work in agriculture and the old saying is "near enough for farm work".
                            #558394
                            bernard towers
                              @bernardtowers37738
                              Sorry but I thought that the idea behind GHTs Upt was the fact that it was for model makers. If you want bigger use a run of the mill drilling machine, it will also have a decent size column.
                              #558398
                              Roger Best
                                @rogerbest89007
                                Posted by Nicholas Wheeler 1 on 15/08/2021 09:41:51:
                                Easy answer – to make it look prettier.
                                Before you choke please remember that beauty is in the eye of the beholder. laugh
                                #558472
                                YouraT
                                  @yourat
                                  Posted by bernard towers on 15/08/2021 20:58:18:
                                  Well, I don't need enormous rigidity – I'm a clockmaker and use mine for bushing and staking purposes, so little in any side forces during use.
                                  Making the arms pretty is a secondary concern, although them not being actively painful to look at is of course a plus
                                  Using a nicely made and finished tool is always more of a pleasure than using a poorly finished one…
                                  Y.
                                  #558490
                                  Martin Kyte
                                    @martinkyte99762
                                    You could always make a cranked column. Couple of bits of PGMS and some 1 1/4 by 3/4" bar. Bore holes to suit the column, Loctite the whole to together and saw away the waste. Bit like a gap bed lathe. You only need to accomodate clockplates as you say and that way you can use all the fittings from your existing pillar tool.
                                    How about that for thinking outside the box.
                                    regards Martin
                                    #558498
                                    YouraT
                                      @yourat
                                      Posted by Martin Kyte on 16/08/2021 14:49:51:
                                      regards Martin
                                      Martin
                                      Genius idea!
                                      I even have a bed like that for my little 8mm Boley watchmaker's lathe – maintaining of alignment is effectively built in, and it avoids having to make any more of those fiddly little clamping handles!
                                      Youra.
