Tuning up my Versatile Vice
Home Forums Manual machine tools Tuning up my Versatile Vice
Viewing 2 posts - 26 through 27 (of 27 total)
  • #468930
    Anonymous
      Posted by Iain Downs on 03/05/2020 18:00:24:
      …….so 0.015mm variation at most (No I've not tried the a matrix of points to see if there are other variances, thought that might be interesting. It also seems (to a naive novice) more inaccuracy than I would have expected from a ground item.
      Not brillant. I haven't measured all four corners on the fixed jaw on my vice but I have measured the two top corners. I couldn't tell the difference with a tenths micrometer. So less than a tenth variation. But the vice was a tad more expensive. smile
      I measured the jaw as I don't use keys but indicate the vice each time I move it. It's convenient to use the back face of the fixed jaw but I wanted to know how it related to the side that mates with the work.
      Iain Downs
        @iaindowns78295
        So, I've stripped the vice down – that is the jaws off and the fixed block removed. A bit of grit under that as well. The edges of the underneath were also a bit rough so I took the edge off.
        I spent some time measuring the fixed block with and without the jaw on.
        The fixed block is quite rough on the side facing the jaw. The depth is various by around 0.03mm across the surface with a distinct channel in the vertical direction around the middle. of the block. There is more variance at the bottom of the block than further up.
        Despite this and the earlier reported irregularity of the jaw, with the jaw on there is a drop of about 0.01mm across the top of the jaw and block assembly and about 0.02 across the bottom.
        I checked out the height of the sliding surfaces on the surface table and they seemed spot on. This measurement was more dubious as the vice is longer and nearly as wide as my surface table!
        After cleaning and re-assembly, I put the vice back on the mill and clocked the fixed jaw. This now shows a deviation of 0.025mm (one thou) from left to right.
        So my conclusion is that the problem was mainly down to dirt in the vice. one thou out across 5 inches is more than enough for just about everything I do. If I have an unexpected need for better than that I wlll take the fixings off and clock it in the normal way.
        Many thanks for all the advice.
        Iain
